Efficient large-context dependency parsing and correction with distributional lexical resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Analyse syntaxique probabiliste en dépendances : approches efficaces à large contexte avec ressources lexicales distributionnelles
This thesis explores ways to improve the accuracy and coverage of efficient statistical dependency parsing. We employ transition-based parsing with models learned using Support Vector Machines (Cortes and Vapnik, 1995), and our experiments are carried out on French. Transition-based parsing is very fast due to the computational efficiency of its underlying algorithms, which are based on a local optimization of attachment decisions. Our first research thread is thus to increase the syntactic context used. From the arc-eager transition system (Nivre, 2008) we propose a variant that simultaneously considers multiple candidate governors for right-directed attachments. We also test parse correction, inspired by Hall and Novák (2005), which revises each attachment in a parse by considering multiple alternative governors in the local syntactic neighborhood. We find that multiple-candidate approaches slightly improve parsing accuracy overall as well as for prepositional phrase attachment and coordination, two linguistic phenomena that exhibit high syntactic ambiguity. Our second research thread explores semi-supervised approaches for improving parsing accuracy and coverage. We test self-training within the journalistic domain as well as for adaptation to the medical domain, using a two-stage parsing approach based on that of McClosky et al. (2006). We then turn to lexical modeling over a large corpus: we model generalized lexical classes to reduce data sparseness, and prepositional phrase attachment preference to improve disambiguation. We find that semi-supervised approaches can sometimes improve parsing accuracy and coverage, without increasing time complexity.
Cette thèse présente des méthodes pour améliorer l'analyse syntaxique probabiliste en dépendances. Nous employons l'analyse à base de transitions avec une modélisation effectuée par des machines à vecteurs supports (Cortes and Vapnik, 1995), et nos expériences sont réalisées sur le français. L'analyse a base de transitions est rapide, de par la faible complexité des algorithmes sous-jacents, eux mêmes fondés sur une optimisation locale des décisions d'attachement. Ainsi notre premier fil directeur est d'élargir le contexte syntaxique utilisé. Partant du système de transitions arc-eager (Nivre, 2008), nous proposons une variante qui considère simultanément plusieurs gouverneurs candidats pour les attachements à droite. Nous testons aussi la correction des analyses, inspirée par Hall and Novák (2005), qui révise chaque attachement en choisissant parmi plusieurs gouverneurs alternatifs dans le voisinage syntaxique. Nos approches améliorent légèrement la précision globale ainsi que celles de l'attachement des groupes prépositionnels et de la coordination. Notre deuxième fil explore des approches semi-supervisées. Nous testons l'auto-entrainement avec un analyseur en deux étapes, basé sur McClosky et al. (2006), pour le domaine journalistique ainsi que pour l'adaptation au domaine médical. Nous passons ensuite à la modélisation lexicale à base de corpus, avec des classes lexicales généralisées pour réduire la dispersion des données, et des préférences lexicales de l'attachement des groupes prépositionnels pour aider à la désambiguïsation. Nos approches améliorent, dans certains cas, la précision et la couverture de l'analyseur, sans augmenter sa complexité théorique.
henestroza2013these.pdf (923.21 Ko) Télécharger le fichier
tel-00860720 , version 1 (10-09-2013)
  • HAL Id : tel-00860720 , version 1
Enrique Henestroza Anguiano. Efficient large-context dependency parsing and correction with distributional lexical resources. Document and Text Processing. Université Paris-Diderot - Paris VII, 2013. English. ⟨NNT : ⟩. ⟨tel-00860720⟩
215 Consultations
470 Téléchargements
