Optimizing the bandwidth utilization in distributed storage systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Optimiser l'utilisation de la bande passante dans les systèmes de stockage distribué
Modern storage systems have to face the surge of the amount of data to handle. At the current scale, it would be an illusion to believe that a single centralized storage device is able to store and retrieve all its users' data. While from the user's viewpoint the storage system remains a single interlocutor, its underlying architecture has become necessarily distributed. In others words, storage is no longer assigned to a centralized storage equipment, but is now distributed between multiple independent storage devices, connected via a network. Therefore, when designing networked storage systems, bandwidth should now be taken into account as a critical resource. In fact, the bandwidth of a system is intrinsically a limited resource which should be handled with care to avoid congestion. The focus of this thesis is to optimize the available bandwidth of distributed storage systems, lowering the impact of churn and failures. The objective is twofold, on the one hand the purpose is to increase the available bandwidth for data exchanges and on the other hand, to decrease the amount of bandwidth consumed by maintenance. We present three distinct contributions in this manuscript. The first contribution of this thesis presents an hybrid peer-to-peer architecture taking into account the low level topology of the network i.e., the presence of gateways between the system and the users. The second contribution proposes an adaptive and user-level timeout mechanism, based on a Bayesian approach. The third contribution describes a repair protocol especially designed for erasure-coded stored data. Finally, this thesis concludes on the possibility of employing interference alignment techniques in order to increase the efficiency of repair protocols especially designed for encoded data.
Les systèmes de stockage actuels font face à une explosion des données à gérer. A l'échelle actuelle, il serait illusoire d'imaginer une unique entité centralisée capable de stocker et de restituer les données de tous ses utilisateurs. Bien que du point de vue de l'utilisateur, le système de stockage apparaît tel un unique interlocuteur, son architecture sous-jacente est nécessairement devenue distribuée. En d'autres termes, le stockage n'est plus assigné à un équipement centralisé, mais est maintenant distribué parmi de multiples entités de stockage indépendantes, connectées via un réseau. Par conséquent, la bande passante inhérente à ce réseau devient une ressource à prendre en compte dans le design d'un système de stockage distribué. En effet, la bande passante d'un système est intrinsèquement une ressource limitée, qui doit être convenablement gérée de manière à éviter toute congestion du système. Cette thèse se propose d'optimiser l'utilisation de la bande passante dans les systèmes de stockage distribués, en limitant l'impact du churn et des défaillances. L'objectif est double, le but est d'une part, de maximiser la bande passante disponible pour les échanges de données, et d'une autre part de réduire la consommation de bande passante inhérente aux opérations de maintenance. Pour ce faire, nous présentons trois contributions distinctes. La première contribution présente une architecture pair-à-pair hybride qui tient compte de la topologie bas-niveau du réseau, c'est à dire la présence de gateways entre les utilisateurs et le système. La seconde contribution propose un mécanisme de timeout adaptatif au niveau utilisateur, basé sur une approche Bayésienne. La troisième contribution décrit un protocole permettant la réparation efficace de données encodées via des codes à effacement. Enfin, cette thèse se conclut sur la possibilité d'utiliser des techniques d'alignement d'interférence, communément utilisées en communication numérique afin d’accroître l'efficacité des protocoles de réparation de données encodées.
VAN_-_KEMPEN_Alexandre.pdf (11.13 Mo) Télécharger le fichier
tel-00862845 , version 1 (17-09-2013)
  • HAL Id : tel-00862845 , version 1
Alexandre van Kempen. Optimizing the bandwidth utilization in distributed storage systems. Other [cs.OH]. Université de Rennes, 2013. English. ⟨NNT : 2013REN1S024⟩. ⟨tel-00862845⟩
346 Consultations
244 Téléchargements
