Context-aware access control and presentation of linked data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Contrôle d'accès et présentation contextuelle pour le Web des données
This thesis discusses the influence of mobile context awareness in accessing the Web of Data from handheld devices. The work dissects this issue into two research questions: how to enable context-aware adaptation for Linked Data consumption, and how to protect access to RDF stores from context-aware devices. The thesis contribution to this first research question is PRISSMA, an RDF rendering engine that extends Fresnel with a context-aware selecting of the best presentation according to mobile context. This operation is performed by an error-tolerant subgraph matching algorithm based on the notion of graph edit distance. The algorithm takes into account the discrepancies between context descriptions and the sensed context, supports heterogeneous context dimensions, and runs on the client-side - to avoid disclosing sensitive context information. The second research activity presented in the thesis is the Shi3ld access control framework for Linked Data servers. Shi3ld has the advantage of being a pluggable filter for generic triple stores, with no need to modify the endpoint itself. It adopts exclusively Semantic Web languages and it does not add new policy definition languages, parsers nor validation procedures. Shi3ld provides protection up to triple level. The thesis describes both PRISSMA and Shi3ld prototypes. Test campaigns show the validity of PRISSMA results, along with memory and response time performance. The Shi3ld access control module has been tested on different triple stores, with and without SPARQL engines. Results show the impact on response time, and demonstrate the feasibility of the approach.
La thèse concerne le rôle joué par le contexte dans l'accès au Web de données depuis les dispositifs mobiles. Le travail analyse ce problème de deux points de vue distincts: adapter au contexte la présentation de triplets, et protéger l'accès aux bases des données RDF depuis les dispositifs mobiles. La première contribution est PRISSMA, un moteur de rendu RDF qui étend Fresnel avec la sélection de la meilleure représentation pour le contexte physique où on se trouve. Cette opération est effectuée par un algorithme de recherche de sous-graphes tolérant aux erreurs basé sur la notion de distance d'édition sur les graphes. L'algorithme considère les différences entre les descriptions de contexte et le contexte détecté par les capteurs, supporte des dimensions de contexte hétérogènes et est exécuté sur le client pour ne pas révéler des informations privées. La deuxième contribution concerne le système de contrôle d'accès Shi3ld. Shi3ld supporte tous les triple stores et il ne nécessite pas de les modifier. Il utilise exclusivement les langages du Web sémantique, et il n'ajoute pas des nouveaux langages de définition de règles d'accès, y compris des analyseurs syntaxiques et des procédures de validation. Shi3ld offre une protection jusqu'au niveau des triplets. La thèse décrit les modèles, algorithmes et prototypes de PRISSMA et de Shi3ld. Des expériences montrent la validité des résultats de PRISSMA ainsi que les performances au niveau de mémoire et de temps de réponse. Le module de contrôle d'accès Shi3ld a été testé avec différents triple stores, avec et sans moteur SPARQL. Les résultats montrent l'impact sur le temps de réponse et démontrent la faisabilité de l'approche.
2013NICE4099.pdf (8.62 Mo) Télécharger le fichier
tel-00934617 , version 1 (22-01-2014)
  • HAL Id : tel-00934617 , version 1
Luca Costabello. Context-aware access control and presentation of linked data. Other [cs.OH]. Université Nice Sophia Antipolis, 2013. English. ⟨NNT : 2013NICE4099⟩. ⟨tel-00934617⟩
479 Consultations
924 Téléchargements
