Throughput Oriented Analytical Models for Performance Estimation on Programmable Accelerators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Modèle analytique de performance orienté débit d'évaluation de performance des accélérateurs programmables
Junjie Lai
  • Fonction : Auteur
  • PersonId : 948920
This thesis work is funded by the ANR PetaQCD project. We have mainly worked on two topics of GPU performance analysis. We have designed an approach which is simple enough for developers to use and can provide more insight into the performance results. And we have designed an approach to estimate the performance upper bound of an application on GPUs and guide the performance optimization. First part of the thesis work was presented at Rapido '12 workshop. We have de- veloped an analytical method and a timing estimation tool (TEG) to predict CUDA application's performance for GT200 generation GPU. TEG passes GPU kernels' as- sembly code and collects information including instruction type, operands, etc. Then TEG can predict GPU applications' performance in cycle-approximate level with the instruction trace and other information collected from Barra simulator. TEG also allows to quantify some performance bottlenecks' penalties. The second main part of this thesis is going to be presented at CGO '13 confer- ence. We developed an approach to estimate GPU applications' performance upper bound based on application analysis and assembly code level benchmarking. With the performance upperbound of an application, we know how much optimization space is left and can decide the optimization e ort. Also with the analysis we can understand which parameters are critical to the performance. As an example, we analyzed the potential peak performance of SGEMM (Single-precision General Matrix Multiply) on Fermi (GF110) and Kepler (GK104) GPUs. Guided by this analysis and using the native assembly language, on average, our SGEMM implementations achieve about 5% better performance than CUBLAS in CUDA 4.1 SDK for large matrices on GTX580. The achieved performance is around 90% of the estimated upper bound performance of SGEMM on GTX580.
L'ère du multi-cœur est arrivée. Les fournisseurs continuent d'ajouter des cœurs aux puces et avec davantage de cœurs, les consommateurs sont persuadés de transformer leurs ordinateurs en plateformes. Cependant, très peu d'applications sont optimisées pour les systèmes multi-cœurs. Il reste difficile de développer efficacement et de façon rentable des applications parallèles. Ces dernières années, de plus en plus de chercheurs dans le domaine de la HPS ont commencé à utiliser les GPU (Graphics Processing Unit, unité de traitement graphique) pour accélérer les applications parallèles. Une GPU est composée de nombreux cœurs plus petits et plus simples que les processeurs de CPU multi-cœurs des ordinateurs de bureau. Il n'est pas difficile d'adapter une application en série à une plateforme GPU. Bien que peu d'efforts soient nécessaires pour adapter de manière fonctionnelle les applications aux GPU, les programmeurs doivent encore passer beaucoup de temps à optimiser leurs applications pour de meilleures performances. Afin de mieux comprendre le résultat des performances et de mieux optimiser les applications de GPU, la communauté GPGPU travaille sur plusieurs thématiques intéressantes. Des modèles de performance analytique sont créés pour aider les développeurs à comprendre le résultat de performance et localiser le goulot d'étranglement. Certains outils de réglage automatique sont conçus pour transformer le modèle d'accès aux données, l'agencement du code, ou explorer automatiquement l'espace de conception. Quelques simulateurs pour applications de GPU sont également lancés. La difficulté évidente pour l'analyse de performance des applications de GPGPU réside dans le fait que l'architecture sous- jacente de la GPU est très peu documentée. La plupart des approches développées jusqu'à présent n'étant pas assez bonnes pour une optimisation efficace des applications du monde réel, et l'architecture des GPU évoluant très rapidement, la communauté a encore besoin de perfectionner les modèles et de développer de nouvelles approches qui permettront aux développeurs de mieux optimiser les applications de GPU. Dans ce travail de thèse, nous avons principalement travaillé sur deux aspects de l'analyse de performance des GPU. En premier lieu, nous avons étudié comment mieux estimer les performances des GPU à travers une approche analytique. Nous souhaitons élaborer une approche suffisamment simple pour être utilisée par les développeurs, et permettant de mieux visualiser les résultats de performance. En second lieu, nous tentons d'élaborer une approche permettant d'estimer la limite de performance supérieure d'une application dans certaines architectures de GPU, et d'orienter l'optimisation des performances.
thesis_jlai-5.pdf (2.15 Mo) Télécharger le fichier
tel-00908579 , version 1 (25-11-2013)
  • HAL Id : tel-00908579 , version 1
Junjie Lai. Throughput Oriented Analytical Models for Performance Estimation on Programmable Accelerators. Hardware Architecture [cs.AR]. Université de Rennes I, 2013. English. ⟨NNT : ⟩. ⟨tel-00908579⟩
396 Consultations
477 Téléchargements
