Multiscale methods in signal processing for adaptive optics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Méthode multi-échelles en traitement du signal pour optique adaptative
In this thesis, we introduce a new approach to wavefront phase reconstruction in Adaptive Optics (AO) from the low-resolution gradient measurements provided by a wavefront sensor, using a non-linear approach derived from the Microcanonical Multiscale Formalism (MMF). MMF comes from established concepts in statistical physics, it is naturally suited to the study of multiscale properties of complex natural signals, mainly due to the precise numerical estimate of geometrically localized critical exponents, called the singularity exponents. These exponents quantify the degree of predictability, locally, at each point of the signal domain, and they provide information on the dynamics of the associated system. We show that multiresolution analysis carried out on the singularity exponents of a high-resolution turbulent phase (obtained by model or from data) allows a propagation along the scales of the gradients in low-resolution (obtained from the wavefront sensor), to a higher resolution. We compare our results with those obtained by linear approaches, which allows us to offer an innovative approach to wavefront phase reconstruction in Adaptive Optics.
Dans cette thèse nous introduisons une approche nouvelle pour la reconstruction d’un front d’ondes en Optique Adaptative (OA), à partir des données de gradients à basse résolution en provenance de l’analyseur de front d’ondes, et en utilisant une approche non-linéaire issue du Formalisme Multiéchelles Mi-crocanonique (FMM). Le FMM est issu de concepts établis en physique statistique, il est naturellement approprié à l’étude des propriétés multiéchelles des signaux naturels complexes, principalement grâce à l’estimation numérique précise des exposants critiques localisés géométriquement, appelés exposants de singularité. Ces exposants quantifient le degré de prédictabilité localement en chaque point du domaine du signal, et ils renseignent sur la dynamique du système associé. Nous montrons qu’une analyse multirésolution opérée sur les exposants de singularité d’une phase turbulente haute résolution (obtenus par modèle ou à partir des données) permet de propager, le long des échelles, les gradients en basse résolution issus de l’analyseur du front d’ondes jusqu’à une résolution plus élevée. Nous comparons nos résultats à ceux obtenus par les approches linéaires, ce qui nous permet de proposer une approche novatrice à la reconstruction de fronts d’onde en Optique Adaptative.
MAJI_SUMAN_KUMAR_2013.pdf (21.75 Mo) Télécharger le fichier
tel-00909085 , version 1 (25-11-2013)
tel-00909085 , version 2 (01-07-2014)
  • HAL Id : tel-00909085 , version 2
Suman Kumar Maji. Multiscale methods in signal processing for adaptive optics. Other [cs.OH]. Université Sciences et Technologies - Bordeaux I, 2013. English. ⟨NNT : 2013BOR14912⟩. ⟨tel-00909085v2⟩
398 Consultations
275 Téléchargements
