Particle approximation and the Laplace method for Bayesian filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Approximation particulaire et méthode de Laplace pour le filtrage bayésien
The thesis deals with the contribution of the Laplace method to the approximation of the Bayesian filter in hidden Markov models with continuous state--space, i.e. in a sequential framework, with target tracking as the main application domain. Originally, the Laplace method is an asymptotic method used to compute integrals, i.e. in a static framework, valid in theory as soon as the function to be integrated exhibits an increasingly dominating maximum point, which brings the essential contribution to the integral. The two main contributions of the thesis are the following. Firstly, we have combined the Laplace method and particle filters: indeed, it is well-known that sequential Monte Carlo methods based on importance sampling are inefficient when the weighting function (here, the likelihood function) is too much spatially localized, e.g. when the variance of the observation noise is too small, whereas this is precisely the situation where the Laplace method is efficient and theoretically justified, hence the natural idea of combining the two approaches. We thus propose an algorithm associating the Laplace method and particle filtering, called the Laplace particle filter. Secondly, we have analyzed the approximation of the Bayesian filter based on the Laplace method only (i.e. without any generation of random samples): the objective has been to control the propagation of the approximation error from one time step to the next time step, in an appropriate asymptotic framework, e.g. when the variance of the observation noise goes to zero, or when the variances of the model noise and of the observation noise jointly go (with the same rate) to zero, or more generally when the information contained in the system goes to infinity, with an interpretation in terms of identifiability.
La thèse porte sur l'apport de la méthode de Laplace pour l'approximation du filtre bayésien dans des modèles de Markov cachés généraux, c'est-à-dire dans un cadre séquentiel, avec comme domaine d'application privilégié la poursuite de cibles mobiles. A la base, la méthode de Laplace est une méthode asymptotique pour le calcul d'intégrales, c'est-à-dire dans un cadre statique, valide en théorie dès que la fonction à intégrer présente un maximum de plus en plus significatif, lequel apporte la contribution essentielle au résultat. En pratique, cette méthode donne des résultats souvent très précis même en dehors de ce cadre de validité théorique. Les deux contributions principales de la thèse sont les suivantes. Premièrement, nous avons utilisé la méthode de Laplace en complément du filtrage particulaire : on sait en effet que les méthodes de Monte Carlo séquentielles basées sur l'échantillonnage pondéré sont mises en difficulté quand la fonction de pondération (ici la fonction de vraisemblance) est trop localisée, par exemple quand la variance du bruit d'observation est trop faible, or c'est précisément là le domaine où la méthode de Laplace est efficace et justifiée théoriquement, d'où l'idée naturelle de combiner les deux points de vue. Nous proposons ainsi un algorithme associant la méthode de Laplace et le filtrage particulaire, appelé le Laplace particle filter. Deuxièmement, nous avons analysé l'approximation du filtre bayésien grâce à la méthode de Laplace seulement (c'est-à-dire sans génération d'échantillons aléatoires) : il s'agit ici de contrôler la propagation de l'erreur d'approximation d'un pas de temps au pas de temps suivant, dans un cadre asymptotique approprié, par exemple quand le bruit d'observation tend vers zéro, ou quand le bruit d'état et le bruit d'observation tendent conjointement (et à la même vitesse) vers zéro, ou plus généralement quand l'information contenue dans le système tend vers l'infini, avec une interprétation en terme d'identifiabilité.
Bui_Quang_Paul.pdf (1.21 Mo) Télécharger le fichier
tel-00910173 , version 1 (27-11-2013)
  • HAL Id : tel-00910173 , version 1
Paul Bui Quang. Particle approximation and the Laplace method for Bayesian filtering. General Mathematics [math.GM]. Université de Rennes, 2013. English. ⟨NNT : 2013REN1S038⟩. ⟨tel-00910173⟩
709 Consultations
230 Téléchargements
