Cryptanalysis of Symmetric-Key Primitives Based on the AES Block Cipher - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Cryptanalyse de primitives symétriques basées sur le chiffrement AES
In this thesis, we are interested in the cryptanalysis of some symmetric primitives using the structural concepts of the current encryption standard AES. We begin by an analysis of the AES itself in three different security models: the standard model, the related-key model and the open-key model. In the standard model, where the adversary tries to recover the secret key, we describe the best differential attacks, improving on the results previously published on this block cipher. Then, we conduct a structural analysis of the AES in the related-key model. We show impossibility results claiming that one cannot prove the security of the structure of the AES against differential cryptanalysis in that model. Finally, in the open-key model, we propose the first distinguisher for 9-round AES-128, which solves a long-lasting open problem in the symmetric community. In a second part, we scrutinize the application of the rebound technique to AES-based permutations. We show that it is possible to control one more round in the first of the two parts of this strategy, which improves the best known results on this type of permutation. This result solves the open problem consisting in increasing the total number of rounds that can be attacked thanks to this technique. We also discuss the possibility to relax some constraints in the second phase to increase its probability of success. This reduces all the time complexities of the results previously published using the rebound technique. We apply these improvements to the Grostl hash function and reach the best cryptanalysis to date on the internal permutation. Finally, we study the ECHO hash function and show how we can apply the rebound technique multiple times to attack more rounds of the internal permutation.
Dans cette thèse, nous nous intéressons à la cryptanalyse de certaines primitives de cryptographie symétrique qui utilisent les concepts de construction du schéma de chiffrement AES. Nous commençons par une analyse de l'AES lui-même dans trois modèles de sécurité différents: le modèle standard, le modèle à clefs reliées et le modèle ouvert. Dans le modèle standard, où l'adversaire cherche à récupérer la clef secrète, nous décrivons les meilleures attaques différentielles existantes sur cet algorithme de chiffrement, en améliorant les attaques différentielles précédemment publiées. Ensuite, nous procédons à une analyse structurelle de l'AES dans le modèle à clefs reliées. Nous montrons des résultats d'impossibilité, indiquant que l'on ne peut pas prouver la sécurité de la structure de l'AES contre les attaques différentielles dans ce modèle. Enfin, dans le modèle ouvert, nous proposons le premier distingueur pour neuf tours d'AES-128, ce qui résout un problème ouvert depuis plusieurs années dans la communauté symétrique. Dans une deuxième partie, nous analysons en détail l'application de l'attaque par rebond sur les primitives basées sur l'AES. Nous montrons qu'il est possible de considérer un tour de plus dans la première des deux phases de cette stratégie, ce qui améliore les meilleurs résultats connus sur les permutations à base d'AES. Ceci résout le problème ouvert consistant à augmenter le nombre total de tours attaqués grâce à cette technique. Nous montrons également qu'il est possible de relâcher certaines contraintes pour augmenter la probabilité de succès de la deuxième étape. Ceci conduit à une diminution des complexités de toutes les attaques publiées. Nous appliquons ces améliorations à la fonction de hachage Grostl, obtenant les meilleures attaques sur la permutation interne. Finalement, nous nous intéressons à la fonction de hachage ECHO pour montrer qu'il est possible d'appliquer plusieurs fois l'attaque par rebond et ainsi attaquer plus de tours de la permutation interne.
phd-thesis-jeremy-jean.pdf (4.62 Mo) Télécharger le fichier
tel-00911049 , version 1 (28-11-2013)
  • HAL Id : tel-00911049 , version 1
Jérémy Jean. Cryptanalysis of Symmetric-Key Primitives Based on the AES Block Cipher. Cryptography and Security [cs.CR]. Ecole Normale Supérieure de Paris - ENS Paris, 2013. English. ⟨NNT : ⟩. ⟨tel-00911049⟩
936 Consultations
2663 Téléchargements
