A Semantic Wiki for Decision Knowledge Management - Application in Oncology
Un wiki sémantique pour la gestion des connaissances décisionnelles - Application à la cancérologie
Decision knowledge is a particular type of knowledge that aims at describing the processes of decision making. In oncology, this knowledge is generally grouped into clinical practice guidelines. The publication of the guidelines is provided by medical organizations as a result of complex collaborative editing processes. The computerization of guides has led to the desire of formalizing the knowledge so as to supply decision-support systems. Thus, editing can be seen as a knowledge acquisition issue. In this context, this thesis aims at proposing methods and tools for factorizing editing guides and their formalization. The first contribution of this thesis is the integration of social semantic web technologies in the editing process. The creation of the semantic wiki OncoLogiK allows to implement this proposal. Thus, a feedback and methods are presented for the migration from a static web solution. The second contribution consists in a solution to exploit the knowledge present in the decision-making guides. Thus, KcatoS framework defines a simple decision tree language for which a translation based on semantic web technologies is developed. KcatoS also proposes an editor of trees, allowing collaborative editing online. The third contribution is to combine in a single system approaches for the creation of clinical guidelines: the approach based on the knowledge symbolized by KcatoS and the documentary approach symbolized by OncoLogiK. Their joint operation can propose a solution benefiting from the advantages of both approaches. Many future works are proposed. Most of them aim at improving services to users and the expressiveness of the knowledge base. Taking into account the work and prospects, a realistic model to create a decision-support system based on clinical guidelines is proposed.
Les connaissances décisionnelles sont un type particulier de connaissances dont le but est de décrire des processus de prise de décision. En cancérologie, ces connaissances sont généralement regroupées dans des guides de bonnes pratiques cliniques. Leur publication est assurée par des organismes médicaux suite à un processus d'édition collaboratif complexe. L'informatisation des guides a conduit à la volonté de formaliser l'ensemble des connaissances contenues de manière à pouvoir alimenter des systèmes d'aide à la décision. Ainsi, leur édition peut être vue comme une problématique d'acquisition des connaissances. Dans ce contexte, le but de cette thèse est de proposer des méthodes et des outils permettant de factoriser l'édition des guides et leur formalisation. Le premier apport de cette thèse est l'intégration des technologies du Web social et sémantique dans le processus d'édition. La création du wiki sémantique OncoLogiK a permis de mettre en œuvre cette proposition. Ainsi, un retour d'expérience et des méthodes sont présentés pour la migration depuis une solution Web statique. Le deuxième apport consiste à proposer une solution pour exploiter les connaissances décisionnelles présentes dans les guides. Ainsi, le framework KCATOS définit un langage d'arbres de décision simple pour lequel une traduction reposant sur les technologies du Web sémantique est développée. KCATOS propose en outre un éditeur d'arbres, permettant l'édition collaborative en ligne. Le troisième apport consiste à concilier dans un même système les approches pour la création des guides de bonnes pratiques informatisés : l'approche s'appuyant sur les connaissances symbolisée par KCATOS et l'approche documentaire d'OncoLogiK. Leur fonctionnement conjoint permet de proposer une solution bénéficiant des avantages des deux approches. De nombreuses perspectives sont exposées. La plupart d'entre elles visent à améliorer les services aux utilisateurs et l'expressivité de la base de connaissances. En prenant en compte le travail effectué et les perspectives, un modèle réaliste visant à faire du projet Kasimir un système d'aide à la décision complet est proposé.
