Towards a safe and secure synchronous language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Vers un langage synchrone sûr et securisé
Pejman Attar
  • Fonction : Auteur
  • PersonId : 770666
  • IdRef : 176040617
This thesis proposes a new approach to parallelism and concurrency, laying the basis for the design of a programming language with a clear and simple formal semantics, enjoying both safety and security properties, while lending itself to an implementation on multicore architectures. We adopted the synchronous programming paradigm, in its reactive variant, which provides a simple alternative to standard concurrent programming by limiting the impact of time-dependent errors ("data-races"). As a first step (Part 1), we considered a reactive orchestration language, DSL, which abstracts away from the memory. To set the basis for a formal treatment of memory and security, we then focussed on a reactive kernel, CRL, equipped with a deterministic parallel operator (Part 2). We proved bounded reactivity of CRL programs. Next, we enriched CRL with mechanisms for information flow control (Part 3). To this end, we first extended CRL with security levels for data. We then defined a type system on the extended language, SSL, which ensures the absence of information leaks. Finally, we added memory to CRL, as well as the notions of agent and site, thus obtaining the model DSLM (Part 4). We structured the memory in such a way that data-races cannot occur, neither within nor among agents. We also investigated the implementation of DSLM on multicore architectures, using the possibility of agent migration between sites. The unification of SSL and DSLM is left for future work.
Cette thèse propose une nouvelle approche du parallélisme et de la concurrence, posant les bases d'un langage de programmation à la fois sûr et "secure" (garantissant la sécurité des données), fondé sur une sémantique formelle claire et simple, tout en étant adapté aux architectures multi-cœur. Nous avons adopté le paradigme synchrone, dans sa variante réactive, qui fournit une alternative simple à la programmation concurrente standard en limitant l'impact des erreurs dépendant du temps ("data-races"). Dans un premier temps, nous avons considéré un langage réactif d'orchestration, DSL, dans lequel on fait abstraction de la mémoire (Partie 1). Dans le but de pouvoir traiter la mémoire et la sécurité, nous avons ensuite étudié (Partie 2) un noyau réactif, CRL, qui utilise un opérateur de parallélisme déterministe. Nous avons prouvé la réactivité bornée des programmes de CRL. Nous avons ensuite équipé CRL de mécanismes pour contrôler le flux d'information (Partie 3). Pour cela, nous avons d'abord étendu CRL avec des niveaux de sécurité pour les données, puis nous avons défini dans le langage étendu, SSL, un système de types permettant d'éviter les fuites d'information. Parallèlement (Partie 4), nous avons ajouté la mémoire à CRL, en proposant le modèle DSLM. En utilisant une notion d'agent, nous avons structuré la mémoire de telle sorte qu'il ne puisse y avoir de "data-races". Nous avons également étudié l'implémentation de DSLM sur les architectures multi-cœur, fondée sur la notion de site et de migration d'un agent entre les sites. L'unification de SSL et de DSLM est une piste pour un travail futur.
2013NICE4148.pdf (1.21 Mo) Télécharger le fichier
tel-00942606 , version 1 (06-02-2014)
  • HAL Id : tel-00942606 , version 1
Pejman Attar. Towards a safe and secure synchronous language. Other [cs.OH]. Université Nice Sophia Antipolis, 2013. English. ⟨NNT : 2013NICE4148⟩. ⟨tel-00942606⟩
Collections
INRIA STAR INRIA2
314 Consultations
286 Téléchargements
