Optimisation combinatoire pour la sélection de variables en régression en grande dimension : Application en génétique animale - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Theses Year : 2013
Combinatorial optimization for variable selection in high dimensional regression: Application in animal genetic
Advances in high-throughput sequencing and genotyping technologies allow to measure large amounts of genomic information. The aim of this work is dedicated to the animal genomic selection is to select a subset of relevant genetic markers to predict a quantitative trait, in a context where the number of genotyped animals is widely lower than the number of markers studied. This thesis introduces a state-of-the-art of existing methods to address the problem. We then suggest to deal with the variable selection in high dimensional regression problem combining combinatorial optimization methods and statistical models. We start by experimentally set two combinatorial optimization methods, the iterated local search and the genetic algorithm, combined with a linear multiple regression and we evaluate their relevance. In the context of animal genomic, family relationships between animals are known and can be an important information. As our approach is flexible we suggest an adaptation to consider these familial relationships through the use of a mixed model. Moreover, the problem of overfitting is particularly present in such data due to the large imbalance between the number of variables studied and the number of animals available, so we suggest an improvement of our approach in order to reduce this over-fitting. The different suggested approaches are validated on data from the literature as well as on real data of Gènes Diffusion.
Le développement des technologies de séquençage et de génotypage haut-débit permet de mesurer, pour un individu, une grande quantité d'information génomique. L'objectif de ce travail est, dans le cadre de la sélection génomique animale, de sélectionner un sous-ensemble de marqueurs génétiques pertinents permettant de prédire un caractère quantitatif, dans un contexte où le nombre d'animaux génotypés est largement inférieur au nombre de marqueurs étudiées. Ce manuscrit présente un état de l'art des méthodes actuelles permettant de répondre à la problématique. Nous proposons ensuite de répondre à notre problématique de sélection de variables en régression en grande dimension en combinant approches d'optimisation combinatoire et modèles statistiques. Nous commençons par paramétrer expérimentalement deux méthodes d'optimisation combinatoire, la recherche locale itérée et l'algorithme génétique, combinées avec une régression li- néaire multiple et nous évaluons leur pertinence. Dans le contexte de la génomique animale les relations familiales entre animaux sont connues et peuvent constituer une information importante. Notre approche étant flexible, nous proposons une adapta- tion permettant de prendre en considération ces relations familiales via l'utilisation d'un modèle mixte. Le problème du sur-apprentissage étant particulièrement présent sur nos données dû au déséquilibre important entre le nombre de variables étudiées et le nombre d'animaux disponibles, nous proposons également une amélioration de notre approche permettant de diminuer ce sur-apprentissage. Les différentes approches proposées sont validées sur des données de la littérature ainsi que sur des données réelles de Gènes Diffusion.
TheseJulieHamon2013.pdf (4.4 Mo) Télécharger le fichier
Dates and versions
tel-00920205 , version 1 (18-12-2013)
Identifiers
  • HAL Id : tel-00920205 , version 1
Cite
Julie Hamon. Optimisation combinatoire pour la sélection de variables en régression en grande dimension : Application en génétique animale. Applications [stat.AP]. Université des Sciences et Technologie de Lille - Lille I, 2013. Français. ⟨NNT : ⟩. ⟨tel-00920205⟩
1182 View
4414 Download
Share
