Scalable data-management systems for Big Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Sur le passage à l'échelle des systèmes de gestion des grandes masses de données
Big Data can be characterized by 3 V’s. • Big Volume refers to the unprecedented growth in the amount of data. • Big Velocity refers to the growth in the speed of moving data in and out management systems. • Big Variety refers to the growth in the number of different data formats. Managing Big Data requires fundamental changes in the architecture of data management systems. Data storage should continue being innovated in order to adapt to the growth of data. They need to be scalable while maintaining high performance regarding data accesses. This thesis focuses on building scalable data management systems for Big Data. Our first and second contributions address the challenge of providing efficient support for Big Volume of data in data-intensive high performance computing (HPC) environments. Particularly, we address the shortcoming of existing approaches to handle atomic, non-contiguous I/O operations in a scalable fashion. We propose and implement a versioning-based mechanism that can be leveraged to offer isolation for non-contiguous I/O without the need to perform expensive synchronizations. In the context of parallel array processing in HPC, we introduce Pyramid, a large-scale, array-oriented storage system. It revisits the physical organization of data in distributed storage systems for scalable performance. Pyramid favors multidimensional-aware data chunking, that closely matches the access patterns generated by applications. Pyramid also favors a distributed metadata management and a versioning concurrency control to eliminate synchronizations in concurrency. Our third contribution addresses Big Volume at the scale of the geographically distributed environments. We consider BlobSeer, a distributed versioning-oriented data management service, and we propose BlobSeer-WAN, an extension of BlobSeer optimized for such geographically distributed environments. BlobSeer-WAN takes into account the latency hierarchy by favoring locally metadata accesses. BlobSeer-WAN features asynchronous metadata replication and a vector-clock implementation for collision resolution. To cope with the Big Velocity characteristic of Big Data, our last contribution feautures DStore, an in-memory document-oriented store that scale vertically by leveraging large memory capability in multicore machines. DStore demonstrates fast and atomic complex transaction processing in data writing, while maintaining high throughput read access. DStore follows a single-threaded execution model to execute update transactions sequentially, while relying on a versioning concurrency control to enable a large number of simultaneous readers.
La problématique "Big Data" peut être caractérisée par trois "V": - "Big Volume" se rapporte à l'augmentation sans précédent du volume des données. - "Big Velocity" se réfère à la croissance de la vitesse à laquelle ces données sont déplacées entre les systèmes qui les gèrent. - "Big Variety" correspond à la diversification des formats de ces données. Ces caractéristiques imposent des changements fondamentaux dans l'architecture des systèmes de gestion de données. Les systèmes de stockage doivent être adaptés à la croissance des données, et se doivent de passer à l'échelle tout en maintenant un accès à hautes performances. Cette thèse se concentre sur la construction des systèmes de gestion de grandes masses de données passant à l'échelle. Les deux premières contributions ont pour objectif de fournir un support efficace des "Big Volumes" pour les applications data-intensives dans les environnements de calcul à hautes performances (HPC). Nous abordons en particulier les limitations des approches existantes dans leur gestion des opérations d'entrées/sorties (E/S) non-contiguës atomiques à large échelle. Un mécanisme basé sur les versions est alors proposé, et qui peut être utilisé pour l'isolation des E/S non-contiguës sans le fardeau de synchronisations coûteuses. Dans le contexte du traitement parallèle de tableaux multi-dimensionels en HPC, nous présentons Pyramid, un système de stockage large-échelle optimisé pour ce type de données. Pyramid revoit l'organisation physique des données dans les systèmes de stockage distribués en vue d'un passage à l'échelle des performances. Pyramid favorise un partitionnement multi-dimensionel de données correspondant le plus possible aux accès générés par les applications. Il se base également sur une gestion distribuée des métadonnées et un mécanisme de versioning pour la résolution des accès concurrents, ce afin d'éliminer tout besoin de synchronisation. Notre troisième contribution aborde le problème "Big Volume" à l'échelle d'un environnement géographiquement distribué. Nous considérons BlobSeer, un service distribué de gestion de données orienté "versioning", et nous proposons BlobSeer-WAN, une extension de BlobSeer optimisée pour un tel environnement. BlobSeer-WAN prend en compte la hiérarchie de latence et favorise les accès aux méta-données locales. BlobSeer-WAN inclut la réplication asynchrone des méta-données et une résolution des collisions basée sur des "vector-clock". Afin de traîter le caractère "Big Velocity" de la problématique "Big Data", notre dernière contribution consiste en DStore, un système de stockage en mémoire orienté "documents" qui passe à l'échelle verticalement en exploitant les capacités mémoires des machines multi-coeurs. Nous montrons l'efficacité de DStore dans le cadre du traitement de requêtes d'écritures atomiques complexes tout en maintenant un haut débit d'accès en lecture. DStore suit un modèle d'exécution mono-thread qui met à jour les transactions séquentiellement, tout en se basant sur une gestion de la concurrence basée sur le versioning afin de permettre un grand nombre d'accès simultanés en lecture.
Tran2013.pdf (5.93 Mo) Télécharger le fichier
tel-00920432 , version 1 (18-12-2013)
  • HAL Id : tel-00920432 , version 1
Viet-Trung Tran. Scalable data-management systems for Big Data. Other [cs.OH]. École normale supérieure de Cachan - ENS Cachan, 2013. English. ⟨NNT : 2013DENS0001⟩. ⟨tel-00920432⟩
1571 Consultations
2643 Téléchargements
