From inter-connecting P2P overlays to co-operating P2P systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
De l'interconnexion à la coopération des systèmes pair-à-pair
Peer-to-peer systems are used by millions of users every day. In many scenarios, it is desirable for the users from different P2P systems to communicate and exchange content or services with each other. This requires co-operation between the P2P systems, which is often difficult or impossible, due to the two following reasons. First is the lack of an inter-overlay routing infrastructure throughout these systems, caused by the incompatibilities in overlay networks on top of which they are built. Second, there are incompatibilities in the application protocols of these systems. The main topic of this thesis is enabling the cooperation between P2P systems. The thesis introduces a cooperation framework for backward-compatible cooperating heterogeneous P2P systems which constitutes two parts. The first one is an inter-overlay routing framework which allows to inter-routing between heterogeneous overlay networks. The second one is the cooperation application, built on the top of the inter-overlay routing framework, which aims at solving the incompatibilities in the application protocols of P2P systems. As a case study of the cooperation framework, we introduce a complete solution for cooperating P2P file-sharing networks which is applicable for all current P2P file-sharing networks. In the second topic of this thesis, we investigate a case study of using inter-connecting P2P overlays for collecting and managing data in smart grid, a typical example of cyber physical system.
Les systèmes pair-à-pair (P2P) sont utilisés par des millions d'usagers tous les jours. Dans beaucoup de cas, un usager souhaite communiquer, échanger du contenu ou des services à travers différents systèmes P2P. Cela requiert de la coopération entre les différents systèmes P2P, ce qui est très souvent difficile ou même impossible à obtenir, à cause des raisons suivantes; in primis, l'absence d'une infrastructure de routage entre les réseaux, ce qui rend la communication étanche et, in secundis, l'incompatibilité des protocoles et des opérations des susdits systèmes. L'objectif principal de cette thèse est celui de permettre la coopération entre systèmes P2P. La thèse introduit un cadre de coopération rétro-compatible entre systèmes P2P hétérogènes constitué de deux parties. La première est un cadre de routage intra-réseaux permettant à des réseaux hétérogènes de communiquer. La deuxième est une application coopérative, conçue à l'aide et au travers du cadre de routage, dont l'objectif est celui de résoudre les incompatibilités protocolaires des systèmes P2P sous-jacents. Comme étude de cas de notre cadre de coopération, on présente une solution complète permettant une coopération entre des réseaux P2P spécialisés dans l'échange des fichiers pouvant s'appliquer aux réseaux P2P actuels. Dans la deuxième partie de la thèse, on présente une étude de cas d'usage de notre architecture d'interconnexion des réseaux P2P pour la collecte et la gestion des données dans réseaux d'électricité intelligents.
Autre [cs.OH]
2013NICE4144.pdf (1.39 Mo) Télécharger le fichier
tel-00937695 , version 1 (28-01-2014)
  • HAL Id : tel-00937695 , version 1
Hoang Giang Ngo. From inter-connecting P2P overlays to co-operating P2P systems. Other [cs.OH]. Université Nice Sophia Antipolis, 2013. English. ⟨NNT : 2013NICE4144⟩. ⟨tel-00937695⟩
379 Consultations
1136 Téléchargements
