Étude expérimentale de la turbulence dans une couche de mélange anisotherme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Expérimental study of turbulence in a non-isothermal mixing layer
The turbulent mixing is studied in a plane mixing layer for a range of initial conditions applied in terms of velocity and temperature gradients between the two parallel inlet flows. A particular attention is paid to the effect of buoyancy forces, especially in the difference between the so-called stable and unstable configurations, in relation to the sign of the vertical temperature gradient applied. In this study, the novel experimental technique called PCTA, for Parameterizable Constant Temperature Anemometry, is used to enable the analysis of correlations between the velocity and temperature fluctuations. In a preliminary work, the PCTA technique, based on the implementation of repetitive multiple-overheat patterns to a hot wire, is extended and adapted for the instantaneous measurement of temperature and two components of velocity with X-wire probes. In a first stage, one point statistics are analysed. They provide a description of the flow features in the similarity region, where the balance equations for turbulent kinetic energy, temperature variance and the momentum and heat fluxes are established. Considering the low Richardson numbers at stake (Rif <0.03), the buoyancy forces appear logically to be quantitatively negligible compared to the main driving forces, but such a low energy forcing mechanism is in fact sufficient, in unstable configuration, to significantly increase the shear stress and the expansion rate of the mixing layer, both phenomena being associated to an enhanced production of turbulence. In a second stage, a joint probability density function analysis highlights the mechanisms and events that significantly contribute to the transverse momentum and heat fluxes. These contributions are differentiated and quantified through a quadrant analysis which emphasizes the dominance of the local movements of entrainment and ejection associated to the Kelvin-Helmholtz structures. Finally, the study focuses on the two points statistics associated with velocity and temperature increments. The behaviour of these increments is studied through their probability densities, examined along with the skewness and kurtosis coefficients. The structure function exponents confirm the stronger intermittency of temperature compared to that of the velocity. The different terms of the Kolmogorov and Yaglom equations are estimated. The balance of these scale budgets allows the quantification of the forcing term that has been introduced in the literature.
L'étude porte sur une couche de mélange plane horizontale générée par la rencontre de deux écoulements parallèles à vitesse et température différentes. Le mélange turbulent est analysé pour différentes conditions initiales en termes de gradients de vitesse et de température. On distingue en particulier des configurations en régime de stratification stable et instable sous l'effet des forces de flottabilité. L'analyse des corrélations entre les fluctuations de vitesse et de température s'appuie sur la technique expérimentale d'anémométrie à température de fil variable (PCTA), qui permet la mesure instantanée de la vitesse et de la température en un même point grâce à la variation périodique et par palier du coefficient de surchauffe du fil chaud utilisé. Un premier travail a consisté à étendre la technique PCTA à l'utilisation de fils croisés pour la mesure simultanée de la température et de deux composantes de la vitesse. Dans un premier temps, les statistiques en un point permettent d'identifier les caractéristiques de l'écoulement dans la région de similitude et d'y établir les équations de bilan pour l'énergie cinétique turbulente, l'intensité des fluctuations de température et les flux de quantité de mouvement et de chaleur. Il apparaît, vu les faibles nombres de Richardson en jeu (Rif<0,03), que les forces de flottabilité sont quasi-négligeables devant les moteurs principaux du mouvement. Pourtant, ce forçage thermique peu énergétique est suffisant, en configuration instable, pour augmenter significativement le taux d'expansion et la contrainte de cisaillement, ce qui correspond de fait à une augmentation de la production de turbulence. L'analyse des densités de probabilité jointes permet ensuite de mettre en évidence les mécanismes et évènements qui contribuent significativement aux flux transversaux de quantité de mouvement et de chaleur. Ces différentes contributions sont différenciées et quantifiées par une analyse en quadrants qui fait ressortir la prépondérance des mouvements d'entraînement et d'éjection. On examine enfin les statistiques en deux points associées aux incréments de vitesse et de température. Le comportement de ces incréments est étudié à travers leurs densités de probabilité et leurs coefficients de dissymétrie et d'aplatissement. Les exposants des fonctions de structure confirment l'intermittence plus grande de la température par rapport à celle de la vitesse. Les différents termes des équations de Kolmogorov et de Yaglom sont mesurés. L'équilibre de ces bilans par échelle permet de quantifier le terme qui intègre les différents forçages proposés dans la littérature.
SODJAVI_-_Kodjovi.pdf (6.76 Mo) Télécharger le fichier
tel-00921507 , version 1 (20-12-2013)
  • HAL Id : tel-00921507 , version 1
Kodjovi Sodjavi. Étude expérimentale de la turbulence dans une couche de mélange anisotherme. Autre [cs.OH]. Université de Rennes, 2013. Français. ⟨NNT : 2013REN1S078⟩. ⟨tel-00921507⟩
377 Consultations
2811 Téléchargements
