A model-based method to manage time properties in component based software systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Une méthode fondée sur les modèles pour gérer les propriétés temporelles des systèmes à composants logiciels
This thesis proposes an approach to integrate the use of time-related stochastic properties in a continuous design process based on models at runtime. Time-related specification of services are an important aspect of component-based architectures, for instance in distributed, volatile networks of computer nodes. The models at runtime approach eases the management of such architectures by maintaining abstract models of architectures synchronized with the physical, distributed execution platform. For self-adapting systems, prediction of delays and throughput of a component assembly is of utmost importance to take adaptation decision and accept evolutions that conform to the specifications. To this aim we define a metamodel extension based on stochastic Petri nets as an internal time model for prediction. We design a library of patterns to ease the specification and prediction of common time properties of models at runtime and make the synchronization of behaviors and structural changes easier. Furthermore, we apply the approach of Aspect-Oriented Modeling to weave the internal time models into timed behavior models of the component and the system. Our prediction engine is fast enough to perform prediction at runtime in a realistic setting and validate models at runtime.
Cette thèse propose une approche pour intégrer l'utilisation des propriétés temporisées stochastiques dans un processus continu de design fondé sur des modèles à l'exécution. La spécification temporelle de services est un aspect important des architectures à base de composants, par exemple dans des réseaux distribués volatiles de nœuds informatiques. L'approche models@runtime facilite la gestion de ces architectures en maintenant des modèles abstraits des archi- tectures synchronisés avec la structure physique de la plate-forme d'exécution distribuée. Pour les systèmes auto-adaptatifs, la prédiction de délais et de débit d'un assemblage de composants est primordial pour prendre la décision d'adaptation et accepter les évolutions qui sont conformes aux spécifications temporelles. Dans ce but, nous définissons une extension du métamodèle fondée sur les réseaux de Petri stochastiques comme un modèle temporisé interne pour la prédiction. Nous concevons une bibliothèque de patrons pour faciliter la spécification et la prédiction des propriétés temporisées classiques de modèles à l'exécution et rendre la synchronisation des comportements et des changements structurels plus facile. D'autre part, nous appliquons l'approche de la modélisation par aspects pour tisser les modèles temporisés internes dans les modèles temporisés de comportement du composant et du système. Notre moteur de prédiction est suffisament rapide pour effectuer la prédiction à l'exécution dans un cadre réaliste et valider des modèles à l'exécution.
NGUYEN_VietHoa.pdf (1.94 Mo) Télécharger le fichier
tel-00923305 , version 1 (02-01-2014)
  • HAL Id : tel-00923305 , version 1
Viet Hoa Nguyen. A model-based method to manage time properties in component based software systems. Software Engineering [cs.SE]. Université Rennes 1, 2013. English. ⟨NNT : ⟩. ⟨tel-00923305⟩
232 Consultations
836 Téléchargements
