Parallelism and distribution for very large scale content-based image retrieval
Parallélisme et distribution pour des bases d'images à très grande échelle
The scale of multimedia collections has grown very fast over the last few years. Facebook stores more than 100 billion images, 200 million are added every day. In order to cope with this growth, methods for content-based image retrieval must adapt gracefully. The work presented in this thesis goes in this direction. Two observations drove the design of the high-dimensional indexing technique presented here. Firstly, the collections are so huge, typically several terabytes, that they must be kept on secondary storage. Addressing disk related issues is thus central to our work. Secondly, all CPUs are now multi-core and clusters of machines are a commonplace. Parallelism and distribution are both key for fast indexing and high-throughput batch-oriented searching. We describe in this manuscript a high-dimensional indexing technique called eCP. Its design includes the constraints associated to using disks, parallelism and distribution. At its core is an non-iterative unstructured vectorial quantization scheme. eCP builds on an existing indexing scheme that is main memory oriented. Our first contribution is a set of extensions for processing very large data collections, reducing indexing costs and best using disks. The second contribution proposes multi-threaded algorithms for both building and searching, harnessing the power of multi-core processors. Datasets for evaluation contain about 25 million images or over 8 billion SIFT descriptors. The third contribution addresses distributed computing. We adapt eCP to the MapReduce programming model and use the Hadoop framework and HDFS for our experiments. This time we evaluate eCP's ability to scale-up with a collection of 100 million images, more than 30 billion SIFT descriptors, and its ability to scale-out by running experiments on more than 100 machines.
Les volumes de données multimédia ont fortement crus ces dernières années. Facebook stocke plus de 100 milliards d'images, 200 millions sont ajoutées chaque jour. Cela oblige les systèmes de recherche d'images par le contenu à s'adapter pour fonctionner à ces échelles. Les travaux présentés dans ce manuscrit vont dans cette direction. Deux observations essentielles cadrent nos travaux. Premièrement, la taille des collections d'images est telle, plusieurs téraoctets, qu'il nous faut obligatoirement prendre en compte les contraintes du stockage secondaire. Cet aspect est central. Deuxièmement, tous les processeurs sont maintenant multi-cœurs et les grilles de calcul largement disponibles. Du coup, profiter de parallélisme et de distribution semble naturel pour accélérer tant la construction de la base que le débit des recherches par lots. Cette thèse décrit une technique d'indexation multidimensionnelle s'appelant eCP. Sa conception prend en compte les contraintes issues de l'usage de disques et d'architectures parallèles et distribuées. eCP se fonde sur la technique de quantification vectorielle non structurée et non itérative. eCP s'appuie sur une technique de l'état de l'art qui est toutefois orientée mémoire centrale. Notre première contribution se compose d'extensions destinées à permettre de traiter de très larges collections de données en réduisant fortement le coût de l'indexation et en utilisant les disques au mieux. La seconde contribution tire profit des architectures multi-cœurs et détaille comment paralléliser l'indexation et la recherche. Nous évaluons cet apport sur près de 25 millions d'images, soit près de 8 milliards de descripteurs SIFT. La troisième contribution aborde l'aspect distribué. Nous adaptons eCP au paradigme Map-Reduce et nous utilisons Hadoop pour en évaluer les performances. Là, nous montrons la capacité de eCP à traiter de grandes bases en indexant plus de 100 millions d'images, soit 30 milliards de SIFT. Nous montrons aussi la capacité de eCP à utiliser plusieurs centaines de cœurs.
Origin : Version validated by the jury (STAR)
