Acoustic-Visual Speech Synthesis by Bimodal Unit Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Synthèse Acoustico-Visuelle de la Parole par Séléction d'Unités Bimodales
Utpala Musti
  • Fonction : Auteur
  • PersonId : 880717
This work deals with audio-visual speech synthesis. In the vast literature available in this direction, many of the approaches deal with it by dividing it into two synthesis problems. One of it is acoustic speech synthesis and the other being the generation of corresponding facial animation. But, this does not guarantee a perfectly synchronous and coherent audio-visual speech. To overcome the above drawback implicitly, we proposed a different approach of acoustic-visual speech synthesis by the selection of naturally synchronous bimodal units. The synthesis is based on the classical unit selection paradigm. The main idea behind this synthesis technique is to keep the natural association between the acoustic and visual modality intact. We describe the audio-visual corpus acquisition technique and database preparation for our system. We present an overview of our system and detail the various aspects of bimodal unit selection that need to be optimized for good synthesis. The main focus of this work is to synthesize the speech dynamics well rather than a comprehensive talking head. We describe the visual target features that we designed. We subsequently present an algorithm for target feature weighting. This algorithm that we developed performs target feature weighting and redundant feature elimination iteratively. This is based on the comparison of target cost based ranking and a distance calculated based on the acoustic and visual speech signals of units in the corpus. Finally, we present the perceptual and subjective evaluation of the final synthesis system. The results show that we have achieved the goal of synthesizing the speech dynamics reasonably well.
Ce travail porte sur la synthèse de la parole audio-visuelle. Dans la littérature disponible dans ce domaine, la plupart des approches traite le problème en le divisant en deux problèmes de synthèse. Le premier est la synthèse de la parole acoustique et l'autre étant la génération d'animation faciale correspondante. Mais, cela ne garantit pas une parfaite synchronisation et cohérence de la parole audio-visuelle. Pour pallier implicitement l'inconvénient ci-dessus, nous avons proposé une approche de synthèse de la parole acoustique-visuelle par la sélection naturelle des unités synchrones bimodales. La synthèse est basée sur le modèle de sélection d'unité classique. L'idée principale derrière cette technique de synthèse est de garder l'association naturelle entre la modalité acoustique et visuelle intacte. Nous décrivons la technique d'acquisition de corpus audio-visuelle et la préparation de la base de données pour notre système. Nous présentons une vue d'ensemble de notre système et nous détaillons les différents aspects de la sélection d'unités bimodales qui ont besoin d'être optimisées pour une bonne synthèse. L'objectif principal de ce travail est de synthétiser la dynamique de la parole plutôt qu'une tête parlante complète. Nous décrivons les caractéristiques visuelles cibles que nous avons conçues. Nous avons ensuite présenté un algorithme de pondération de la fonction cible. Cet algorithme que nous avons développé effectue une pondération de la fonction cible et l'élimination de fonctionnalités redondantes de manière itérative. Elle est basée sur la comparaison des classements de coûts cible et en se basant sur une distance calculée à partir des signaux de parole acoustiques et visuels dans le corpus. Enfin, nous présentons l'évaluation perceptive et subjective du système de synthèse final. Les résultats montrent que nous avons atteint l'objectif de synthétiser la dynamique de la parole raisonnablement bien.
Main.pdf (1.94 Mo) Télécharger le fichier
tel-01749331 , version 2 (11-01-2014)
tel-01749331 , version 1 (29-03-2018)
  • HAL Id : tel-01749331 , version 2
Utpala Musti. Acoustic-Visual Speech Synthesis by Bimodal Unit Selection. Machine Learning [cs.LG]. Université de Lorraine, 2013. English. ⟨NNT : 2013LORR0003⟩. ⟨tel-01749331v2⟩
319 Consultations
136 Téléchargements
