Couplage de modèles de dimensions hétérogènes et application en hydrodynamique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Dimensionally heterogeneous models coupling and hydrodynamic application
Manel Tayachi
The work presented here focuses on electrodes made of silicon, a promising material to replace graphite as an anode active material for Li-ion Batteries (LIBs). The first part of the manuscript is dedicated to the study of silicon (de)lithiation mechanisms by Auger Electron Spectroscopy (AES). By using this technique of surface characterization, which allows investigating individual particles in their electrode environment, our results show that the first silicon lithiation occurs through a two-phase region mechanism cr-Si / a-Li3,1Si, whereas the following (de)lithiation steps are solid solution type process. Upon (de)alloying with lithium, silicon particles undergo huge volume variations leading to a quick capacity fading. By combining several techniques of characterization, the failure mechanisms of a silicon electrode are studied during aging. In particular, by using electrochemical impedance spectroscopy and mercury porosimetry analyses, an impressive dynamic upon cycling of the electrode porosity is shown. A model, which mainly attributes the capacity fading to the Solid Electrolyte Interphase instability at the silicon particles surface, is proposed. To try to stabilize this passivation layer and thus improve silicon electrodes electrochemical performances, the influence of two parameters is studied: the electrolyte and the “lithiation domain” of silicon; the latter is associated with the evolution of the active material composition upon cycling. Finally, by using these last results, promising performances are obtained for silicon electrode containing LIBs.
Les travaux de thèse présentés dans ce manuscrit portent sur l’étude d’électrodes de silicium, matériau prometteur pour remplacer le graphite en tant que matériau actif d’électrode négative pour accumulateur Li-ion. Les mécanismes de (dé)lithiation du silicium sont d’abord étudiés, par Spectroscopie des Electrons Auger (AES). En utilisant cette technique de caractérisation de surface, qui permet d’analyser les particules individuellement dans leur environnement d’électrode, nos résultats montrent que la première lithiation du silicium s’effectue selon un mécanisme biphasé cr-Si / a-Li3,1Si tandis que les processus de (dé)lithiation suivants apparaissent complètement différents et sont du type solution solide. Ces mécanismes d’insertion / désinsertion du lithium conduisent à des variations volumiques importantes des particules de matériau actif lors du cyclage, à l’origine d’une détérioration rapide des performances électrochimiques. En combinant plusieurs techniques de caractérisation, les mécanismes de dégradation d’une électrode de silicium sont étudiés au cours du vieillissement. En utilisant en particulier la spectroscopie d’impédance électrochimique et des analyses par porosimétrie mercure, une véritable dynamique de la porosité de l’électrode est mise en évidence lors du cyclage. Un modèle de dégradation, mettant en cause principalement l’instabilité de la Solid Electrolyte Interphase (SEI) à la surface des particules de silicium, est proposé. Pour tenter de stabiliser cette couche de passivation et ainsi améliorer les performances électrochimiques des électrodes de silicium, l’influence de deux paramètres est étudiée : l’électrolyte et le « domaine de lithiation » du silicium, ce dernier paramètre étant associé à l’évolution de la composition du matériau actif lors du cyclage. A l’issue de ces travaux, des performances prometteuses sont obtenues pour des accumulateurs Li-ion comprenant une électrode de silicium.
these_manel_version_finale.pdf (1.73 Mo) Télécharger le fichier
tel-00930084 , version 1 (14-01-2014)
  • HAL Id : tel-00930084 , version 1
Manel Tayachi. Couplage de modèles de dimensions hétérogènes et application en hydrodynamique. Mathématiques générales [math.GM]. Université de Grenoble, 2013. Français. ⟨NNT : 2013GRENM031⟩. ⟨tel-00930084⟩
478 Consultations
265 Téléchargements
