Indices de Sobol généralisés pour variables dépendantes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Generalized Sobol sensitivity indices for dependent variables
A mathematical model aims at characterizing a complex system or process that is too expensive to experiment. However, in this model, often strongly non linear, input parameters can be affected by a large uncertainty including errors of measurement of lack of information. Global sensitivity analysis is a stochastic approach whose objective is to identify and to rank the input variables that drive the uncertainty of the model output. Through this analysis, it is then possible to reduce the model dimension and the variation in the output of the model. To reach this objective, the Sobol indices are commonly used. Based on the functional ANOVA decomposition of the output, also called Hoeffding decomposition, they stand on the assumption that the incomes are independent. Our contribution is on the extension of Sobol indices for models with non independent inputs. In one hand, we propose a generalized functional decomposition, where its components is subject to specific orthogonal constraints. This decomposition leads to the definition of generalized sensitivity indices able to quantify the dependent inputs' contribution to the model variability. On the other hand, we propose two numerical methods to estimate these constructed indices. The first one is well-fitted to models with independent pairs of dependent input variables. The method is performed by solving linear system involving suitable projection operators. The second method can be applied to more general models. It relies on the recursive construction of functional systems satisfying the orthogonality properties of summands of the generalized decomposition. In parallel, we illustrate the two methods on numerical examples to test the efficiency of the techniques.
Dans un modèle qui peut s'avérer complexe et fortement non linéaire, les paramètres d'entrée, parfois en très grand nombre, peuvent être à l'origine d'une importante variabilité de la sortie. L'analyse de sensibilité globale est une approche stochastique permettant de repérer les principales sources d'incertitude du modèle, c'est-à-dire d'identifier et de hiérarchiser les variables d'entrée les plus influentes. De cette manière, il est possible de réduire la dimension d'un problème, et de diminuer l'incertitude des entrées. Les indices de Sobol, dont la construction repose sur une décomposition de la variance globale du modèle, sont des mesures très fréquemment utilisées pour atteindre de tels objectifs. Néanmoins, ces indices se basent sur la décomposition fonctionnelle de la sortie, aussi connue sous le nom de décomposition de Hoeffding. Mais cette décomposition n'est unique que si les variables d'entrée sont supposées indépendantes. Dans cette thèse, nous nous intéressons à l'extension des indices de Sobol pour des modèles à variables d'entrée dépendantes. Dans un premier temps, nous proposons une généralisation de la décomposition de Hoeffding au cas où la forme de la distribution des entrées est plus générale qu'une distribution produit. De cette décomposition généralisée aux contraintes d'orthogonalité spécifiques, il en découle la construction d'indices de sensibilité généralisés capable de mesurer la variabilité d'un ou plusieurs facteurs corrélés dans le modèle. Dans un second temps, nous proposons deux méthodes d'estimation de ces indices. La première est adaptée à des modèles à entrées dépendantes par paires. Elle repose sur la résolution numérique d'un système linéaire fonctionnel qui met en jeu des opérateurs de projection. La seconde méthode, qui peut s'appliquer à des modèles beaucoup plus généraux, repose sur la construction récursive d'un système de fonctions qui satisfont les contraintes d'orthogonalité liées à la décomposition généralisée. En parallèle, nous mettons en pratique ces méthodes sur différents cas tests.
squelette.pdf (2.13 Mo) Télécharger le fichier
tel-00930229 , version 1 (17-01-2014)
  • HAL Id : tel-00930229 , version 1
Gaëlle Chastaing. Indices de Sobol généralisés pour variables dépendantes. Méthodologie [stat.ME]. Université de Grenoble, 2013. Français. ⟨NNT : ⟩. ⟨tel-00930229⟩
1058 Consultations
4541 Téléchargements
