Modeling functional and non-functional properties of systems based on a multi-view approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Une approche multi-vue pour la modélisation système de propriétés fonctionnelles et non-fonctionnelles
At the system-level, experts specify functional and non-functional properties by employing their own theoretical models, tools and environments. Such experts attempt to use the most adequate formalisms to verify the defined system properties in a specific domain. Nevertheless, each one of these experts' views is supported on a common base and impacts directly or indirectly the models described by the other experts. Therefore, it is essential to keep a semantic coherence among the different points of view, and also to be able to reconcile and to include all the points of view before undertaking the different phases of the analysis. This thesis proposes a specific domain model called PRISMSYS. This model is based on a model-driven multi-view approach where the concepts, and the relationships between them, are described for each experts' domain. Moreover, these concepts maintain a relation with a backbone model. PRISMSYS allows keeping a semantic coherence among the different views by means of the manipulation of events and logical clocks. PRISMSYS is represented in an UML profile, supported as much as possible by SysML and MARTE. The semantic model, which preserves the view coherence, is specified by using CCSL, a declarative formal language for the specification of causal and temporal relationships between events of different views. The environment proposed by PRISMSYS allows the co-simulation of the model and its analysis. The approach is illustrated taking as case study an electronic system, where the main domain analysis is power consumption.
Au niveau système, un ensemble d'experts spécifient des propriétés fonctionnelles et non fonctionnelles en utilisant chacun leurs propres modèles théoriques, outils et environnements. Chacun essaye d'utiliser les formalismes les plus adéquats en fonction des propriétés à vérifier. Cependant, chacune des vues d'expertise pour un domaine s'appuie sur un socle commun et impacte direct ou indirectement les modèles décrits par les autres experts. Il est donc indispensable de maintenir une cohérence sémantique entre les différents points de vue, et de pouvoir réconcilier et agréger chacun des points de vue avant de poursuivre les différentes phases d'analyse. Cette thèse propose un modèle, dénommé PRISMSYS, qui s'appuie sur une approche multi-vue dirigée par les modèles et dans laquelle pour chacun des domaines, chaque expert décrit les concepts de son domaine et la relation que ces concepts entretiennent avec le modèle socle. L'approche permet de maintenir la cohérence sémantique entre les différentes vues à travers la manipulation d'événements et d'horloges logiques. PRISMSYS est basé sur un profil UML qui s'appuie autant que possible sur les profils SysML et MARTE. Le modèle sémantique qui maintien la cohérence est spécifié avec le langage CCSL qui est un langage formel déclaratif pour la spécification de relations causales et temporelles entre les événements de différentes vues. L'environnement proposé par PRISMSYS permet la co-simulation du modèle et l'analyse. L'approche est illustrée en s'appuyant sur une architecture matérielle dans laquelle le domaine d'analyse privilégié est un domaine de consommation de puissance.
2013NICE4153.pdf (4.48 Mo) Télécharger le fichier
tel-00931001 , version 1 (14-01-2014)
tel-00931001 , version 2 (07-04-2014)
  • HAL Id : tel-00931001 , version 2
Carlos Ernesto Gómez Cárdenas. Modeling functional and non-functional properties of systems based on a multi-view approach. Other [cs.OH]. Université Nice Sophia Antipolis, 2013. English. ⟨NNT : 2013NICE4153⟩. ⟨tel-00931001v2⟩
763 Consultations
864 Téléchargements
