Thèse Année : 2013
Robust visual detection and tracking of complex objects : applications to space autonomous rendez-vous and proximity operations
Détection et suivi visuels robustes d'objets complexes : applications au rendezvous spatial autonome
In this thesis, we address the issue of fully localizing a known object through computer vision, using a monocular camera, what is a central problem in robotics. A particular attention is here paid on space robotics applications, with the aims of providing a unified visual localization system for autonomous navigation purposes for space rendezvous and proximity operations. Two main challenges of the problem are tackled: initially detecting the targeted object and then tracking it frame-by-frame, providing the complete pose between the camera and the object, knowing the 3D CAD model of the object. For detection, the pose estimation process is based on the segmentation of the moving object and on an efficient probabilistic edge-based matching and alignment procedure of a set of synthetic views of the object with a sequence of initial images. For the tracking phase, pose estimation is handled through a 3D model-based tracking algorithm, for which we propose three different types of visual features, pertinently representing the object with its edges, its silhouette and with a set of interest points. The reliability of the localization process is evaluated by propagating the uncertainty from the errors of the visual features. This uncertainty besides feeds a linear Kalman filter on the camera velocity parameters. Qualitative and quantitative experiments have been performed on various synthetic and real data, with challenging imaging conditions, showing the efficiency and the benefits of the different contributions, and their compliance with space rendezvous applications.
Dans cette thèse nous étudions le fait de localiser complètement un objet connu par vision artificielle, en utilisant une caméra monoculaire, ce qui constitue un problème majeur dans des domaines comme la robotique. Une attention particulière est ici portée sur des applications de robotique spatiale, dans le but de concevoir un système de localisation visuelle pour des opérations de rendez-vous spatial autonome. Deux composantes principales du problème sont abordées: celle de la localisation initiale de l'objet ciblé, puis celle du suivi de cet objet image par image, donnant la pose complète entre la caméra et l'objet, connaissant le modèle 3D de l'objet. Pour la détection, l'estimation de pose est basée sur une segmentation de l'objet en mouvement et sur une procédure probabiliste d'appariement et d'alignement basée contours de vues synthétiques de l'objet avec une séquence d'images initiales. Pour la phase de suivi, l'estimation de pose repose sur un algorithme de suivi basé modèle 3D, pour lequel nous proposons trois différents types de primitives visuelles, dans l'idée de décrire l'objet considéré par ses contours, sa silhouette et par un ensemble de points d'intérêts. L'intégrité du système de localisation est elle évaluée en propageant l'incertitude sur les primitives visuelles. Cette incertitude est par ailleurs utilisée au sein d'un filtre de Kalman linéaire sur les paramètres de vitesse. Des tests qualitatifs et quantitatifs ont été réalisés, sur des données synthétiques et réelles, avec notamment des conditions d'image difficiles, montrant ainsi l'efficacité et les avantages des différentes contributions proposées, et leur conformité avec un contexte de rendez vous spatial.
PETIT_Antoine.pdf (12.8 Mo) Télécharger le fichier
Origine Version validée par le jury (STAR)
tel-00931604 , version 1 (15-01-2014)
tel-00931604 , version 2 (21-08-2014)
  • HAL Id : tel-00931604 , version 2
Antoine Petit. Robust visual detection and tracking of complex objects : applications to space autonomous rendez-vous and proximity operations. Computer Vision and Pattern Recognition [cs.CV]. Université de Rennes, 2013. English. ⟨NNT : 2013REN1S190⟩. ⟨tel-00931604v2⟩
809 Consultations
1574 Téléchargements
More
