Communication inter-cœurs optimisée pour le parallélisme de flux. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Optimized inter-core communication for pipeline parallelism
Among the various paradigms of parallelization, pipeline parallelism has the advantage of maintaining sequentiality of algorithms, thus being applicable in case of data dependencies. More over, the stream-computing extension for OpenMP proposed by Pop and Cohen allows to apply this form of parallelization without needing a complete rewrite of the code, by simply adding annotations to it. However, due to the *importance* of the communication needed between the cores, the performances obtained by following this paradigm depends very much on the communication algorithm used. Yet, the communication algorithm used in this extension relies on queues that can handle several producers and consumers while applications using pipeline parallelism mainly works with linear communication chains. To improve the performances of pipeline parallelism implemented by the stream-computing extension for OpenMP, this thesis propose to use, whenever possible, a more specialized communication algorithm called BatchQueue. By only handling the special case of a communication with one producer and one consumer, BatchQueue can reach throughput up to two time faster than existing algorithms. Furthermore, once integrated to the stream-computing extension for OpenMP, the evaluation shows that BatchQueue can improve speedup of application up to a factor 2 as well. The study thus shows that using a more efficient specialized communication algorithm can have a significant impact on overall performances of application implementing pipeline parallelism.
Parmi les différents paradigmes de programmation parallèle, le parallélisme de flux présente l'avantage de conserver la séquentialité des algorithmes et d'être ainsi applicable en présence de dépendances de données. De plus, l'extension de calcul par flux pour OpenMP proposée par Pop et Cohen permet de mettre en œuvre cette forme de parallélisme sans requérir de réécriture complète du code, en y ajoutant simplement des annotations. Cependant, en raison de l'importance de la communication nécessaire entre les cœurs de calcul, les performances obtenues en suivant ce paradigme sont très dépendantes de l'algorithme de communication utilisé. Or l'algorithme de communication utilisé dans cette extension repose sur des files gérant plusieurs producteurs et consommateurs alors que les applications mettant en œuvre le parallélisme de flux fonctionnent principalement avec des chaînes de communication linéaires. Afin d'améliorer les performances du parallélisme de flux mis en œuvre par l'extension de calcul par flux pour OpenMP, cette thèse propose d'utiliser, lorsque cela est possible, un algorithme de communication plus spécialisé nommé BatchQueue. En ne gérant que le cas particulier d'une communication avec un seul producteur et un seul consommateur, BatchQueue atteint des débits jusqu'à deux fois supérieurs à ceux des algorithmes existants. De plus, une fois intégré à l'extension de calcul par flux pour OpenMP, l'évaluation montre que BatchQueue permet d'améliorer l'accélération des applications jusqu'à un facteur 2 également. L'étude montre ainsi qu'utiliser des algorithmes de communication spécialisés plus efficaces peut avoir un impact significatif sur les performances générales des applications mettant en œuvre le parallélisme de flux.
These-manuscript.pdf (8.63 Mo) Télécharger le fichier
tel-00931833 , version 1 (15-01-2014)
  • HAL Id : tel-00931833 , version 1
Thomas Preud'Homme. Communication inter-cœurs optimisée pour le parallélisme de flux.. Calcul parallèle, distribué et partagé [cs.DC]. Université Pierre et Marie Curie - Paris VI, 2013. Français. ⟨NNT : ⟩. ⟨tel-00931833⟩
305 Consultations
378 Téléchargements
