A basis for intrusion detection in distributed systems using kernel-level data tainting. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Détection d'intrusions dans les systèmes distribués par propagation de teinte au niveau noyau
Modern organisations rely intensively on information and communicationtechnology infrastructures. Such infrastructures offer a range of servicesfrom simple mail transport agents or blogs to complex e-commerce platforms,banking systems or service hosting, and all of these depend on distributedsystems. The security of these systems, with their increasing complexity, isa challenge. Cloud services are replacing traditional infrastructures byproviding lower cost alternatives for storage and computational power, butat the risk of relying on third party companies. This risk becomesparticularly critical when such services are used to host privileged companyinformation and applications, or customers' private information. Even in thecase where companies host their own information and applications, the adventof BYOD (Bring Your Own Device) leads to new security relatedissues.In response, our research investigated the characterization and detection ofmalicious activities at the operating system level and in distributedsystems composed of multiple hosts and services. We have shown thatintrusions in an operating system spawn abnormal information flows, and wedeveloped a model of dynamic information flow tracking, based on taintmarking techniques, in order to detect such abnormal behavior. We trackinformation flows between objects of the operating system (such as files,sockets, shared memory, processes, etc.) and network packetsflowing between hosts. This approach follows the anomaly detection paradigm.We specify the legal behavior of the system with respect to an informationflow policy, by stating how users and programs from groups of hosts areallowed to access or alter each other's information. Illegal informationflows are considered as intrusion symptoms. We have implemented this modelin the Linux kernel (the source code is availableat http://www.blare-ids.org), as a Linux Security Module (LSM), andwe used it as the basis for practical demonstrations. The experimentalresults validated the feasibility of our new intrusion detection principles.
Les systèmes d'information actuels, qu'il s'agisse de réseaux d'entreprises, deservices en ligne ou encore d'organisations gouvernementales, reposent trèssouvent sur des systèmes distribués, impliquant un ensemble de machinesfournissant des services internes ou externes. La sécurité de tels systèmesd'information est construite à plusieurs niveaux (défense en profondeur). Lors de l'établissementde tels systèmes, des politiques de contrôle d'accès, d'authentification, defiltrage (firewalls, etc.) sont mises en place afin de garantir lasécurité des informations. Cependant, ces systèmes sont très souventcomplexes, et évoluent en permanence. Il devient alors difficile de maintenirune politique de sécurité sans faille sur l'ensemble du système (quand bienmême cela serait possible), et de résister aux attaques auxquelles ces servicessont quotidiennement exposés. C'est ainsi que les systèmes de détectiond'intrusions sont devenus nécessaires, et font partie du jeu d'outils desécurité indispensables à tous les administrateurs de systèmes exposés enpermanence à des attaques potentielles.Les systèmes de détection d'intrusions se classifient en deux grandes familles,qui diffèrent par leur méthode d'analyse: l'approche par scénarios et l'approchecomportementale. L'approche par scénarios est la plus courante, et elle estutilisée par des systèmes de détection d'intrusions bien connus tels queSnort, Prélude et d'autres. Cette approche consiste à reconnaître des signaturesd'attaques connues dans le trafic réseau (pour les IDS réseau) et des séquencesd'appels systèmes (pour les IDS hôtes). Il s'agit donc de détecter descomportements anormaux du système liés à la présence d'attaques. Bien que l'onpuisse ainsi détecter un grand nombre d'attaques, cette approche ne permet pasde détecter de nouvelles attaques, pour lesquelles aucune signature n'estconnue. Par ailleurs, les malwares modernes emploient souvent des techniquesdites de morphisme binaire, afin d'échapper à la détection parsignatures.L'approche comportementale, à l'inverse de l'approche par signature, se basesur la modélisation du fonctionnement normal du système. Cette approche permetainsi de détecter de nouvelles attaques tout comme des attaques plus anciennes,n'ayant recours à aucune base de données de connaissance d'attaques existantes.Il existe plusieurs types d'approches comportementales, certains modèles sontstatistiques, d'autres modèles s'appuient sur une politique de sécurité.Dans cette thèse, on s'intéresse à la détection d'intrusions dans des systèmesdistribués, en adoptant une approche comportementale basée sur une politique desécurité. Elle est exprimée sous la forme d'une politique de flux d'information. Les fluxd'informations sont suivis via une technique de propagation de marques (appeléeen anglais « taint marking ») appliquées sur les objets du systèmed'exploitation, directement au niveau du noyau. De telles approchesexistent également au niveau langage (par exemple par instrumentation de lamachine virtuelle Java, ou bien en modifiant le code des applications), ou encoreau niveau de l'architecture (en émulant le microprocesseur afin de tracer lesflux d'information entre les registres, pages mémoire etc.), etpermettent ainsi une analyse fine des flux d'informations. Cependant, nous avons choisi de nous placer au niveau du système d'exploitation, afin de satisfaire les objectifs suivants:• Détecter les intrusions à tous les niveaux du système, pas spécifiquement au sein d'une ou plusieurs applications.• Déployer notre système en présence d'applications natives, dont le code source n'est pas nécessairement disponible (ce qui rend leur instrumentation très difficile voire impossible).• Utiliser du matériel standard présent sur le marché. Il est très difficile de modifier physiquement les microprocesseurs, et leur émulation a un impact très important sur les performances du système.
Hauser_Christophe_These_VF_Cines.pdf (1.45 Mo) Télécharger le fichier
tel-01066750 , version 1 (22-09-2014)
  • HAL Id : tel-01066750 , version 1
Christophe Hauser. A basis for intrusion detection in distributed systems using kernel-level data tainting.. Other. Supélec; QUEENSLAND UNIVERSITY OF TECHNOLOGY, 2013. English. ⟨NNT : 2013SUPL0013⟩. ⟨tel-01066750⟩
674 Consultations
976 Téléchargements
