Aero-acoustic Shape Optimization of a Supersonic Business Jet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Optimisation de forme aéro-acoustique d'un avion d'affaires supersonique
This work addresses the development of original numerical methods for the aero-acoustic optimal shape design of supersonic con gurations. The rst axis of the present research is the enhancement of numerical approaches for the prediction of sonic boom. The three dimensional CFD near- eld prediction matched using a multipole decomposition approach coupled with atmospheric propagation using on a ray-tracing algorithm is improved by the integration of an automated anisotropic mesh adaptation process. The second part of this work focuses on the formulation and development of design techniques for the optimization of a supersonic wing-body con guration. An inverse design module, AIDA, is able to determine an equivalent con guration provided a target shaped signature at ground level corresponding to a low-boom pro le. In order to improve both the aerodynamic and the acoustic performance, direct shape optimization techniques are used to solve single and multi-disciplinary optimization problems and a detailed analysis is carried out.
Ce travail porte sur le developpement de m ethodes num eriques innovantes pour la conception a ero -acoustique optimale de forme des con gurations supersoniques. Ce manuscrit pr esente tout d'abord l'analyse et le d eveloppement des approches num eriques pour la pr evision du bang sonique . Le couplage du calcul CFD tridimensionnel en champ proche prenant en compte la d ecomposition multipolaire de Fourier et la propagation atmosph erique bas ee sur un algorithme de trac e de rayons est am elior e par l'int egration d'un processus automatique d' adaptation anisotrope de maillage. La deuxi eme partie de ce travail se concentre sur l' elaboration et l'application des techniques de conception pour l'optimisation d'une con guration aile-fuselage supersonique. Un module de conception inverse, AIDA , fournit a partir d'une signature acoustique cible au sol a faible bang sonique la g eom etrie de la con- guration correspondante. Pour am eliorer a la fois les performances acoustique et a erodynamique, des techniques d'optimisation directes de forme sont utilis ees pour r esoudre des probl emes d'optimisation mono et multi- disciplinaires et une analyse d etaill ee est r ealis ee. Des strat egies innovantes bas ees sur la coop eration et les jeux comp etitifs sont en n appliqu ees au probl eme d'optimisation multidisciplinaire o rant une alternative aux algorithmes traditionnels MDO . L'hybridation de ces deux strat egies ouvre la voie a une nouvelle fa con d'explorer le front de Pareto de mani ere e cace. Celle-ci est mise en application sur un cas pratique.
home.pdf (33.74 Mo) Télécharger le fichier
tel-00938396 , version 1 (29-01-2014)
tel-00938396 , version 2 (19-02-2014)
  • HAL Id : tel-00938396 , version 2
Andrea Minelli. Aero-acoustic Shape Optimization of a Supersonic Business Jet. Analysis of PDEs [math.AP]. Université Nice Sophia Antipolis, 2013. English. ⟨NNT : ⟩. ⟨tel-00938396v2⟩
628 Consultations
912 Téléchargements
