Modèles Mathématiques pour la compétition et la coexistence des espèces microbiennes dans un chémostat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Mathematical models for the competition and coexistence of microbial species in the chemostat
This thesis focuses on the mathematical analysis of models of several species in competition on a single resource in a chemostat. The objective is to model and show the coexistence of microbial species by different mechanisms to better realize biodiversity found in nature like in the bioreactors. We are interested mainly in three mechanisms of coexistence : 1. The inter-specific competition between populations of micro-organisms and intra-specific between individuals of the same species. 2. The flocculation where the species who wins the competition inhibits its growth by the formation of flocs to be able to coexist with the other species. In fact, these flocs consume less substrate than isolated bacteria since they have less access to the substrate, given that this access to the substrate is proportional to the outside surface of the floc. 3. The density-dependence which the model can be construct from the flocculation model by assuming that the dynamics of flocculation is faster than the growth of the species. In this density-dependent model, the growth rate depends not only on the density of substrate but also on the density of biomass, and the removal rate of biomass is not constant but depends also on the density of biomass. Finally, we studied a 3-step model of anaerobic digestion with enzymatic degradation of the substrate (organic matter) that can partly be under a solid form. The mathematical analysis shows that this model may exhibit the quadri-stability with washout of none, one or two species according to the initial condition. The mathematical study of the qualitative behavior of different models of the chemostat, allowed us to better understand the competition and the coexistence of microbial species.
Cette thèse porte sur l'analyse mathématique des modèles de compétition de plusieurs espèces microbiennes sur une seule ressource dans un chémostat. L'objectif est de modéliser et démontrer la coexistence des espèces par divers mécanismes pour mieux rendre compte de la biodiversité que l'on trouve dans la nature, ainsi que dans les bioréacteurs. Nous nous somme intéressés principalement à trois mécanismes de coexistence : 1. La compétition inter-spécifique entre les populations de micro-organismes et intra-spécifiques entre les individus de la même espèce. 2. La floculation où l'espèce la plus compétitive inhibe sa propre croissance par la formation des flocs pour pouvoir coexister avec les autres espèces. En fait, ces bactéries en flocs consomment moins du substrat que les bactéries isolées puisqu'elles ont un moins bon accès au substrat, étant donné que cet accès au substrat est proportionnel à la surface extérieur du floc. 3. La densité-dépendance dont le modèle peut être construit à partir du modèle de floculation, en supposant que la dynamique de floculation est plus rapide que la croissance des espèces. Dans ce modèle densité-dépendant le taux de croissance dépend non seulement de la densité du substrat, mais aussi, de la densité de la biomasse, et le taux de prélèvement de la biomasse n'est pas constant mais dépend aussi de la densité de la biomasse. Enfin, nous avons étudié un modèle de digestion anaérobie à trois étapes avec dégradation enzymatique du substrat (matière organique), dont une partie peut être sous forme particulaire. L'analyse mathématique montre que le modèle peut présenter la quadri-stabilité avec lessivage d'aucune, d'une ou de deux espèces selon la condition initiale. L'étude mathématique du comportement qualitatif de différents modèles du chémostat, nous a permis de mieux comprendre la compétition et la coexistence des espèces microbiennes.
These-Finale-22-7-2013.pdf (6.16 Mo) Télécharger le fichier
tel-00940100 , version 1 (31-01-2014)
  • HAL Id : tel-00940100 , version 1
  • PRODINRA : 314679
Radhouane Fekih-Salem. Modèles Mathématiques pour la compétition et la coexistence des espèces microbiennes dans un chémostat. Systèmes dynamiques [math.DS]. Université Montpellier II - Sciences et Techniques du Languedoc, 2013. Français. ⟨NNT : ⟩. ⟨tel-00940100⟩
657 Consultations
908 Téléchargements
