Simulation d'événements rares par Monte Carlo dans les réseaux hautement fiables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Rare event Monte Carlo simulation for highly reliable networks
Network reliability determination, is an NP-hard problem. For instance, in telecommunications, it is desired to evaluate the probability that a selected group of nodes (e.g. just one pair) communicate or not, or an a electric power systems, where we need to estimate the risk that electricity is not delivered to certain nodes, or in transportation systems, where damaged routes can be determined. In all these cases, a set of disconnected nodes can lead to critical financials security consequences. A precise estimation of the reliability is, therefore, needed. Modern communication networks are characterized by their large size, so the estimation trough Monte Carlo simulation process is often the favorable choice. The standard form of this algorithm samples N copies of the graph (representing the network) independently, where the unreliability is estimated from the proportion of N copies for which the selected nodes are not connected. In these networks, the probabilities of failure of connections are small and therefore the network failure becomes rare. This poses major challenges to estimate the network reliability. In this thesis we present different techniques based on importance sampling (IS) for reliability network estimation, which consist in doing a certain changes in the sampling probability arcs. With this technique, the original sampling probabilities arcs are replaced by new probabilities, requiring to multiply the old estimator with the likelihood ratio to remain unbiased. We are particularly interested in the study and determination of reliability of highly reliable networks represented by static graphs. In this case the unreliability is very small, in some case it is around 10−10, which make the standard Monte Carlo approach useless, because in order to estimate this probability we need a sample size larger than ten billion. For a good estimation of system reliability with minimum cost, we have studied, analyzed and developed the following concepts : - First we developed a method based on(IS). The sampling process of all graph arcs with the new probability is represented by a Markov chain, where at each step we determine the link state by the new probability determined by the states of all links previously sampled. Values of these probabilities are approximated by the minimal cut have largest probability of unreliability. Proves of the good properties of the estimator based on IS are obtained. - A second development, consists in applying techniques of series parallel reductions at each stage of sampling IS in order to reduce the variance and the time simulation. - The last point is to combine the unreliability approximation based on minimal cut which underestimates the unreliability with another approximation, an overestimation based on minimal path, for better approximate zero variance estimator. Optimization algorithms are used to find the optimal adjustment factor the two approximations.
Le calcul de la fiabilité des réseaux est en général un problème NP-difficile. On peut par exemple, s'intéresser à la fiabilité des systèmes de télécommunications où l'on veut évaluer la probabilité qu'un groupe sélectionné de noeuds (qui peut être juste une paire) puissent communiquer, ou s'intéresser aux systèmes d'alimentation électriques où l'on veut estimer le risque que l'électricité n'est pas fournie à certains noeuds, ou encore, étudier la fiabilité des systèmes de transport, où les liens représentent les routes et sont soumis à des dommages. Dans tous ces cas, un ensemble de noeuds déconnectés peut avoir des conséquences critiques, que ce soit financières ou au niveau de la sécurité. Une estimation précise de la fiabilité est ainsi nécessaire. Les réseaux de communication moderne se caractérisent par leur grande taille, donc l'estimation via la simulation de Monte Carlo devient souvent un choix favorable. Un algorithme de Monte Carlo sous sa forme standard, échantillonne N réalisations du graphe (représentant le réseau) indépendantes, et la défiabilité est estimée à partir de la proportion des N réalisations pour lesquelles les noeuds sélectionnés ne sont pas connectés. Dans ces réseaux, les probabilités de défaillance des liens (arcs) sont généralement petites et donc les pannes d'un réseau deviennent des événements rares. Cela pose un défi majeur pour estimer la fiabilité d'un réseau. Dans cette thèse, nous présentons différentes techniques basées sur l'échantillonnage préférentiel (Importance Sampling en anglais IS), pour l'estimation de la fiabilité d'un réseau. Grace à cette technique les probabilités originales d'échantillonnage des arcs sont remplacées par de nouvelles probabilités, puis multiplier l'ancien estimateur par le quotient de vraisemblance (likelihood ratio) pour rester sans biais. On s'intéresse tout particulièrement à l'étude et au calcul de la fiabilité des réseaux hautement fiables et représentés par des graphes statiques. Dans ce cas la défiabilité est très petite, parfois de l'ordre de 10−10, ce qui rend l'approche standard de Monte Carlo inutile, car pour pouvoir estimer cette probabilité il nous faut un échantillon de taille supérieure à dix milliards. Pour une bonne estimation de la fiabilité des réseaux au moindre coût, nous avons étudié, analysé et développé les points suivants : - En premier lieu nous avons développé une méthode basée sur l'échantillonnage préférentiel. Le processus d'échantillonnage de tous les arcs du graphe sous la nouvelle probabilité est représenté par une chaîne de Markov, telle qu'à chaque étape on détermine l'état d'un arc avec une nouvelle probabilité déterminée en fonction de l'état de tous les arcs précédemment échantillonnés. Les fonctions valeurs de la nouvelle probabilité sont approchées par les coupes minimales possédant la plus grande probabilité de défiabilité, elle est le produit des défiabilités des arcs de la coupe. Des preuves de bonnes propriétés de l'estimateur basé sur l'échantillonnage préférentiel sont faites. - Un deuxième point a été abordé et développé, consiste à appliquer des techniques de réduction série-parallèle à chaque étape de l'échantillonnage IS précédemment décrit, afin de réduire substantiellement et la variance et le temps de simulation. - Le dernier point consiste à combiner pour approximation de l'estimateur à variance nulle, l'approximation de la défiabilité par une coupe minimale qui sous-estime la défiabilité avec une autre approximation basée sur les chemins minimaux qui la sur-estime. Des algorithmes d'optimisation sont utilisés pour rechercher le facteur optimal d'ajustement des deux approximations pour minimiser la variance.
these-v5-3.pdf (886.23 Ko) Télécharger le fichier
tel-00940140 , version 1 (31-01-2014)
  • HAL Id : tel-00940140 , version 1
Samira Saggadi. Simulation d'événements rares par Monte Carlo dans les réseaux hautement fiables. Modélisation et simulation. Université Rennes 1, 2013. Français. ⟨NNT : ⟩. ⟨tel-00940140⟩
708 Consultations
1205 Téléchargements
