Etude de deux problèmes de contrôle stochastique : Put Américain avec dividendes discrets et principe de programmation dynamique avec contraintes en probabilités - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Study of two stochastic optimization problems : American put option in a discrete dividend model and dynamic programming principle with probability constraints
In this thesis, we address two problems of stochastic optimal control. Each problem constitutes a different Part in this document. The first problem addressed is very precise, it is the valuation of American contingent claims and more specifically the American Put in the presence of discrete dividends (Part I). The second one is more general, since it is the proof of the existence of a dynamic programming principle under expectation constraints in a discrete time framework (Part II). Although the two problems are quite distinct, the dynamic programming principle is at the heart of these two problems. The relationship between the value of an American Put and a free boundary problem has been proved by McKean. The boundary of this problem has a clear economic meaning since it corresponds at all times to the upper limit of the asset price above which the holder of such an option would exercise immediately his right to sell. The shape of the boundary in the presence of discrete dividends has not been solved to the best of our knowledge. Under the assumption that the dividend is a deterministic function of asset prices at the date just before the dividend payment, we investigate how the boundary is modified. In the neighborhood of dividend dates and in the model of Chapter 3, we know what the monotonicity of the border is, and we quantify its local behavior. In Chapter 3, we show that the smooth-fit property is satisfied at any date except for those of the payment of dividends. In both Chapters 3 and 4, we are able to give conditions to guarantee the continuity of the border outside dates of dividend. Part II was originally motivated by the optimal management of the production of an hydroelectric power plant with a probability constraint on the reservoir level on certain dates. Using Balder's works on Young's relaxation of optimal control problems, we focus more specifically on their resolution by dynamic programming. In Chapter 5, we extend results of Evstigneev to the framework of Young measures. We show that dynamic programming can be used to solve some problems with conditional expectations constraints. Through the ideas of Bouchard, Elie, Soner and Touzi on stochastic target problems with controlled loss, we show in Chapter 6 that a problem with expectation constraints can be reduced to a problem with conditional expectation constraints. Finally, as a special case, we show that the initial problem of dam management can be solved by dynamic programming.
Dans cette thèse, nous traitons deux problèmes de contrôle optimal stochastique. Chaque problème correspond à une Partie de ce document. Le premier problème traité est très précis, il s'agit de la valorisation des contrats optionnels de vente de type Américain (dit Put Américain) en présence de dividendes discrets (Partie I). Le deuxième est plus général, puisqu'il s'agit dans un cadre discret en temps de prouver l'existence d'un principe de programmation dynamique sous des contraintes en probabilités (Partie II). Bien que les deux problèmes soient assez distincts, le principe de programmation dynamique est au coeur de ces deux problèmes. La relation entre la valorisation d'un Put Américain et un problème de frontière libre a été prouvée par McKean. La frontière de ce problème a une signification économique claire puisqu'elle correspond à tout instant à la borne supérieure de l'ensemble des prix d'actifs pour lesquels il est préférable d'exercer tout de suite son droit de vente. La forme de cette frontière en présence de dividendes discrets n'avait pas été résolue à notre connaissance. Sous l'hypothèse que le dividende est une fonction déterministe du prix de l'actif à l'instant précédant son versement, nous étudions donc comment la frontière est modifiée. Au voisinage des dates de dividende, et dans le modèle du Chapitre 3, nous savons qualifier la monotonie de la frontière, et dans certains cas quantifier son comportement local. Dans le Chapitre 3, nous montrons que la propriété du smooth-fit est satisfaite à toute date sauf celles de versement des dividendes. Dans les deux Chapitres 3 et 4, nous donnons des conditions pour garantir la continuité de cette frontière en dehors des dates de dividende. La Partie II est originellement motivée par la gestion optimale de la production d'une centrale hydro-electrique avec une contrainte en probabilité sur le niveau d'eau du barrage à certaines dates. En utilisant les travaux de Balder sur la relaxation de Young des problèmes de commande optimale, nous nous intéressons plus spécifiquement à leur résolution par programmation dynamique. Dans le Chapitre 5, nous étendons au cadre des mesures de Young des résultats dûs à Evstigneev. Nous établissons alors qu'il est possible de résoudre par programmation dynamique certains problèmes avec des contraintes en espérances conditionnelles. Grâce aux travaux de Bouchard, Elie, Soner et Touzi sur les problèmes de cible stochastique avec perte contrôlée, nous montrons dans le Chapitre 6 qu'un problème avec contrainte en espérance peut se ramener à un problème avec des contraintes en espérances conditionnelles. Comme cas particulier, nous prouvons ainsi que le problème initial de la gestion du barrage peut se résoudre par programmation dynamique.
these.pdf (1.24 Mo) Télécharger le fichier
tel-00940506 , version 1 (01-02-2014)
  • HAL Id : tel-00940506 , version 1
Maxence Jeunesse. Etude de deux problèmes de contrôle stochastique : Put Américain avec dividendes discrets et principe de programmation dynamique avec contraintes en probabilités. Probabilités [math.PR]. Université de Marne la Vallée, 2013. Français. ⟨NNT : ⟩. ⟨tel-00940506⟩
821 Consultations
885 Téléchargements
