Certified Compilation and Worst-Case Execution Time Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Compilation formellement vérifiée et estimation du pire temps d'éxécution
André Oliveira Maroneze
  • Fonction : Auteur
  • PersonId : 773343
  • IdRef : 180615963
Safety-critical systems - such as electronic flight control systems and nuclear reactor controls - must satisfy strict safety requirements. We are interested here in the application of formal methods - built upon solid mathematical bases - to verify the behavior of safety-critical systems. More specifically, we formally specify our algorithms and then prove them correct using the Coq proof assistant - a program capable of mechanically checking the correctness of our proofs, providing a very high degree of confidence. In this thesis, we apply formal methods to obtain safe Worst-Case Execution Time (WCET) estimations for C programs. The WCET is an important property related to the safety of critical systems, but its estimation requires sophisticated techniques. To guarantee the absence of errors during WCET estimation, we have formally verified a WCET estimation technique based on the combination of two main methods: a loop bound estimation and the WCET estimation via the Implicit Path Enumeration Technique (IPET). The loop bound estimation itself is decomposed in three steps: a program slicing, a value analysis based on abstract interpretation, and a loop bound calculation stage. Each stage has a chapter dedicated to its formal verification. The entire development has been integrated into the formally verified C compiler CompCert. We prove that the final estimation is correct and we evaluate its performances on a set of reference benchmarks. The contributions of this thesis include (a) the formalization of the techniques used to estimate the WCET, (b) the estimation tool itself (obtained from the formalization), and (c) the experimental evaluation. We conclude that our formally verified development obtains interesting results in terms of precision, but it requires special precautions to ensure the proof effort remains manageable. The parallel development of specifications and proofs is essential to this end. Future works include the formalization of hardware cost models, as well as the development of more sophisticated analyses to improve the precision of the estimated WCET.
Les systèmes informatiques critiques - tels que les commandes de vol électroniques et le contrôle des centrales nucléaires - doivent répondre à des exigences strictes en termes de sûreté de fonctionnement. Nous nous intéressons ici à l'application de méthodes formelles - ancrées sur de solides bases mathématiques - pour la vérification du comportement des logiciels critiques. Plus particulièrement, nous spécifions formellement nos algorithmes et nous les prouvons corrects, à l'aide de l'assistant à la preuve Coq - un logiciel qui vérifie mécaniquement la correction des preuves effectuées et qui apporte un degré de confiance très élevé. Nous appliquons ici des méthodes formelles à l'estimation du Temps d'Exécution au Pire Cas (plus connu par son abréviation en anglais, WCET) de programmes C. Le WCET est une propriété importante pour la sûreté de fonctionnement des systèmes critiques, mais son estimation exige des analyses sophistiquées. Pour garantir l'absence d'erreurs lors de ces analyses, nous avons formellement vérifié une méthode d'estimation du WCET fondée sur la combinaison de deux techniques principales: une estimation de bornes de boucles et une estimation du WCET via la méthode IPET (Implicit Path Enumeration Technique). L'estimation de bornes de boucles est elle-même décomposée en trois étapes : un découpage de programmes, une analyse de valeurs opérant par interprétation abstraite, et une méthode de calcul de bornes. Chacune de ces étapes est formellement vérifiée dans un chapitre qui lui est dédiée. Le développement a été intégré au compilateur C formellement vérifié CompCert. Nous prouvons que le résultat de l'estimation est correct et nous évaluons ses performances dans des ensembles de benchmarks de référence dans le domaine. Les contributions de cette thèse incluent la formalisation des techniques utilisées pour estimer le WCET, l'outil d'estimation lui-même (obtenu à partir de la formalisation), et l'évaluation expérimentale des résultats. Nous concluons que le développement fondé sur les méthodes formelles permet d'obtenir des résultats intéressants en termes de précision, mais il exige des précautions particulières pour s'assurer que l'effort de preuve reste maîtrisable. Le développement en parallèle des spécifications et des preuves est essentiel à cette fin. Les travaux futurs incluent la formalisation de modèles de coût matériel, ainsi que le développement d'analyses plus sophistiquées pour augmenter la précision du WCET estimé.
main.pdf (7.45 Mo) Télécharger le fichier
tel-01064869 , version 1 (17-09-2014)
tel-01064869 , version 2 (07-02-2015)
  • HAL Id : tel-01064869 , version 2
André Oliveira Maroneze. Certified Compilation and Worst-Case Execution Time Estimation. Cryptography and Security [cs.CR]. Université de Rennes, 2014. English. ⟨NNT : 2014REN1S030⟩. ⟨tel-01064869v2⟩
835 Consultations
603 Téléchargements
