Génération de maillages non structurés volumiques de modèles géologiques pour la simulation de phénomènes physiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Unstructured volumetric meshing of geological models for physical phenomenon Simulations
Arnaud Botella
  • Fonction : Auteur
  • PersonId : 773032
  • IdRef : 197621147
The geomodeling main goals are to represent and understand the subsurface. The geological structures have an important role for understanding and predicting its physical behavior. We defined a geological model as a set of structures and their connections. The meshes are numerical supports to solve the equations modeling the subsurface physics. So it is important to build a mesh representing a geological model to take into account the impact of these structures on the subsurface phenomena. The objective of this thesis is to develop volumetric meshing methods for geological models. We propose a volumetric unstructured meshing method to build two mesh types: an adaptive tetrahedral mesh and an hex-dominant mesh (i.e. made of tetrahedra, triangular prisms, quadrilateral pyramids and hexahedra). This method generates first a tetrahedral mesh that can respect different types of data: (1) a geological model defined by its boundaries to capture the structures in the volumetric mesh, (2) well paths represented as a set of segments, (3) a mesh size property to control the mesh element edge length and (4) a direction field to control vertex/element alignments inside the mesh to increase some features such as elements with right angles. Then, this tetrahedral mesh can be transformed in a mixed-element mesh. The method recognizes combinatorial relationships between tetrahedra to identify new elements such as prisms, pyramids and hexahedra. This method is then used to generate meshes whose features correspond to a given application in order to reduce errors during numerical computation. Several application domains are considered such as geomechanical, ow and wave propagation simulations.
Les objectifs principaux de la géomodélisation sont la représentation et la compréhension du sous-sol. Les structures géologiques ont un rôle important pour comprendre et prédire son comportement physique. Nous avons défini un modèle géologique comme étant composé d'un ensemble de structures et de leurs connexions. Les maillages sont des supports numériques servant à résoudre les équations modélisant la physique du sous-sol. Il est donc important de construire un maillage représentant un modèle géologique afin de prendre en compte l'impact de ces structures dans les phénomènes du sous-sol. L'objectif de cette thèse est de développer des méthodes de maillage volumique pour les modèles géologiques. Nous proposons une méthode de génération de maillages non structurés volumiques permettant de construire deux types de maillages : un maillage tétraédrique et un maillage hex-dominant (c'est-à-dire composé de tétraèdres, prismes à base triangulaire, pyramides à base quadrilatérale et hexaèdres). Cette méthode génère dans un premier temps un maillage tétraédrique qui peut respecter différents types de données : (1) un modèle géologique défini par frontières afin de capturer les structures dans le maillage volumique, (2) des trajectoires de puits représentées par un ensemble de segments, (3) une propriété de taille d'éléments afin de contrôler la longueur des arêtes des éléments et (4) un champ de directions pour contrôler des alignements de sommets/éléments dans le maillage afin de favoriser certaines caractéristiques comme des éléments possédant des angles droits. Dans un deuxième temps, ce maillage tétraédrique peut être transformé en un maillage multi-éléments. La méthode reconnaît des relations combinatoires entre tétraèdres permettant l'identification de nouveaux éléments comme les prismes, les pyramides et les hexaèdres. Cette méthode est ensuite utilisée pour générer des maillages aux caractéristiques spécifiques correspondant à une application donnée afin de limiter les erreurs lors du calcul numérique. Plusieurs domaines d'applications sont considérés tels que les simulations géomécaniques, d'écoulements et de propagation d'ondes sismiques.
DDOC_T_2016_0097_BOTELLA.pdf (13.21 Mo) Télécharger le fichier
tel-01435058 , version 1 (13-01-2017)
  • HAL Id : tel-01435058 , version 1
Arnaud Botella. Génération de maillages non structurés volumiques de modèles géologiques pour la simulation de phénomènes physiques. Géophysique [physics.geo-ph]. Université de Lorraine, 2016. Français. ⟨NNT : 2016LORR0097⟩. ⟨tel-01435058⟩
351 Consultations
1597 Téléchargements
