Idiopathic central precocious puberty in a Klinefelter patient: highlights on gonadotropin levels and pathophysiology - ACL en SVSAE Accéder directement au contenu
Article Dans Une Revue Basic and clinical andrology Année : 2020
Background: Idiopathic central precocious puberty (ICPP) is supposed to be non-existent in a context of testicular destruction that is typically present in Klinefelter syndrome (KS). Herein, we describe a rare case of ICPP in a Klinefelter patient (47,XXY) with 2 maternal X chromosomes. Moreover, we highlight the differences in gonadotropin levels in comparison to males with ICPP and a normal karyotype. Case presentation: An 8 years old boy with a history of cryptorchidism was evaluated for precocious puberty (Tanner staging: P2/G3). Both testes measured 25x35mm. His hormonal profile confirmed a central origin of precocious puberty with high serum testosterone (4.3 ng/ml), luteinizing hormone [LH (3.5 UI/l)] and follicle stimulating hormone [FSH (7.7 UI/l)] levels. Luteinizing hormone-releasing hormone (LHRH) test amplified LH and FSH secretion to 24 and 14 UI/l respectively. Brain magnetic resonance imaging (MRI) was normal. No MKRN3 mutation was detected. He was treated for ICPP for two years. During puberty, he suffered from hypergonadotropic hypogonadism leading to the diagnosis of KS (47,XXY karyotype). Chromosomal analysis by fluorescent multiplex polymerase chain reaction (PCR) using X chromosome microsatellite markers identified 2 maternal X chromosomes. Analysing 8 cases of KS developing ICPP (our reported case and 7 other published cases) revealed that these KS patients with ICPP have higher LH and FSH levels during ICPP episode than in ICPP patients with a normal karyotype (ICPP with KS vs ICPP with a normal karyotype: LH levels 9.4 ± 12 vs 1.1 ± 0.6 UI/l; FSH levels 23.1 ± 38.5 vs 2.7 ± 1.5 UI/l). Furthermore, their response to gonadotropin-releasing hormone (GnRH) stimulation is characterized by excessive LH and FSH secretion (LH levels post-GnRH: 58 ± 48 vs 15.5 ± 0.8 UI/l; FSH levels post-GnRH: 49.1 ± 62.1 vs 5.7 ± 3.9 UI/l). Conclusions: ICPP in boys is extremely rare. The pathophysiology of ICPP in KS is unknown. However, maternal X supplementary chromosome and early testicular destruction may play a significant role in the initiation of ICPP, in part explaining the relative "overrepresentation of ICPP in KS. Thus, karyotype analysis could be considered for boys suffering from ICPP, especially if testicular size is smaller or gonadotropins are significantly elevated.
s12610-020-00117-1.pdf (522.7 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03095346 , version 1 (04-01-2021)
Salwan Maqdasy, Bertrand Barres, Gaelle Salaun, Marie Batisse-Lignier, Celine Pebrel-Richard, et al.. Idiopathic central precocious puberty in a Klinefelter patient: highlights on gonadotropin levels and pathophysiology. Basic and clinical andrology, 2020, 30 (1), pp.19. ⟨10.1186/s12610-020-00117-1⟩. ⟨hal-03095346⟩
119 Consultations
66 Téléchargements
