Translation termination efficiency modulates ATF4 response by regulating ATF4 mRNA translation at 5' short ORFs - Traduction eucaryote Accéder directement au contenu
Article Dans Une Revue Nucleic Acids Research Année : 2012
The activating transcription factor 4 (ATF4) promotes transcriptional upregulation of specific target genes in response to cellular stress. ATF4 expression is regulated at the translational level by two short open reading frames (uORFs) in its 5′-untranslated region (5′-UTR). Here, we describe a mechanism regulating ATF4 expression in translation termination-deficient human cells. Using microarray analysis of total RNA and polysome-associated mRNAs, we show that depletion of the eucaryotic release factor 3a (eRF3a) induces upregulation of ATF4 and of ATF4 target genes. We show that eRF3a depletion modifies ATF4 translational control at regulatory uORFs increasing ATF4 ORF translation. Finally, we show that the increase of REDD1 expression, one of the upregulated targets of ATF4, is responsible for the mTOR pathway inhibition in eRF3a-depleted cells. Our results shed light on the molecular mechanisms connecting eRF3a depletion to mammalian target of rapamycin (mTOR) pathway inhibition and give an example of ATF4 activation that bypasses the signal transduction cascade leading to the phosphorylation of eIF2α. We propose that in mammals, in which the 5′-UTR regulatory elements of ATF4 mRNA are strictly conserved, variations in translation termination efficiency allow the modulation of the ATF4 response.
2012_Ghezala_Nucleic Acids Research_1.pdf (4.17 Mo) Télécharger le fichier
hal-01544180 , version 1 (29-05-2020)
Paternité - Pas d'utilisation commerciale
Hayet Ait Ghezala, Béatrice Jolles, Samia Salhi, Katia Castrillo, Wassila Carpentier, et al.. Translation termination efficiency modulates ATF4 response by regulating ATF4 mRNA translation at 5' short ORFs. Nucleic Acids Research, 2012, 40 (19), pp.9557 - 9570. ⟨10.1093/nar/gks762⟩. ⟨hal-01544180⟩
244 Consultations
106 Téléchargements
