PAPR Analysis as a Ratio of Two Random Variables: Application to Multicarrier Systems with Low Subcarriers Number - Advanced Connectivity Lab, IRT b<>com Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Communications Année : 2018
The distribution of the peak to average power ratio (PAPR) of multicarrier systems is studied in the context of signals featuring low subcarriers number. Considering the mean power of the signal as a random variable, a general cumulative distribution function of the PAPR is suggested. We show that the new formulation is valid not only for low subcarriers number, but also for larger subcarriers number. Thus, an asymptotic analysis using a large subcarriers number proves a perfect concordance between the suggested approach and the state-of-the-art derivations only valid for large subcarriers number. All the theoretical developments are supported through simulations, and we discuss the case of oversampled signals as well.
TCOMM2857460-1.pdf (227.42 Ko) Télécharger le fichier
hal-01847274 , version 1 (07-08-2018)
Vincent Savaux, Yves Louët. PAPR Analysis as a Ratio of Two Random Variables: Application to Multicarrier Systems with Low Subcarriers Number. IEEE Transactions on Communications, 2018, 66 (11), pp.5732-5739. ⟨10.1109/TCOMM.2018.2857460⟩. ⟨hal-01847274⟩
170 Consultations
611 Téléchargements
