Considering Sync Word and Header Error Rates for Performance Assessment in LoRa System - Network and Security Domain, IRT b<>com Accéder directement au contenu
Vincent Savaux
Patrick Savelli
This paper deals with a general and complete analysis of the frame error rate in LoRa system, not only considering the payload error rate, but also the sync word (carrying network information) and the header (carrying control information) error rates. It is proved that, in the high signal-to-noise ratio (SNR) range, it is more likely to reject a LoRa frame due to an erroneous sync word estimation rather than an erroneous header or payload decoding, due to the fact that it is not coded. The theoretical results are then verified through simulations.
Mots clés
2021044287 (1).pdf (456.36 Ko) Télécharger le fichier
hal-03200449 , version 1 (16-04-2021)
  • HAL Id : hal-03200449 , version 1
Vincent Savaux, Christophe Delacourt, Patrick Savelli. Considering Sync Word and Header Error Rates for Performance Assessment in LoRa System. Wireless telecommunications Symposium, Apr 2021, San Francisco (virtual), United States. ⟨hal-03200449⟩
64 Consultations
467 Téléchargements
