Formalization of a security access control model for the 5G system - Trust and Identity Lab, IRT b<>com Accéder directement au contenu
David Espes
Frédéric Cuppens
  • Fonction : Auteur
Philippe Bertin
Philippe Le Parc
  • Fonction : Auteur
  • PersonId : 1079535
The race for implementing communication services over 5G has already begun. For this, network coverage is needed and resource sharing is a way to achieve it. Therefore, each provider enforces its own security requirements. Under this scenario, it is necessary to consider security access mechanisms and policy rules, to regulate how interconnections are made between the shared network functions and how to allow specific traffic. The existing models do not address all the needs inherent to the 5G architecture, such as multi-tenancy, multi-domain and multiple security levels. To solve this challenge, this paper defines a novel access control model for 5G, leveraging on the best characteristics of traditional access control models used in operating systems and cloud scenarios. The security properties in our model obey the functional requirements within the 5G system as well as towards the customers. The actions and type of traffic of the system can be specified and enforced via an access control policy. Besides addressing the 5G system, our innovation is general enough to be applied over other types of architectures, proving its scalability and capability to incorporate more security features.
Formalization_of_a_security_model_for_5G_System_v7.pdf (178.34 Ko) Télécharger le fichier
hal-02970893 , version 1 (19-10-2020)
  • HAL Id : hal-02970893 , version 1
Luis Suárez, David Espes, Frédéric Cuppens, Philippe Bertin, Cao-Thanh Phan, et al.. Formalization of a security access control model for the 5G system. 11th International Conference on Network of the Future (NoF 2020), Oct 2020, Bordeaux, France. ⟨hal-02970893⟩
82 Consultations
172 Téléchargements
