Thermodynamic Modelling of an Ejector with Compressible Flow by a One-Dimensional Approach - Laboratoire Chimie Moléculaire, Génie des Procédés Chimiques et Énergétiques (EA7341) Accéder directement au contenu
Article Dans Une Revue Entropy Année : 2012
The purpose of this study is the dimensioning of the cylindrical mixing chamber of a compressible fluid ejector used in particular in sugar refineries for degraded vapor re‑compression at the calandria exit, during the evaporation phase. The method used, known as the “integral” or “thermodynamic model”, is based on the model of the one‑dimensional isentropic flow of perfect gases with the addition of a model of losses. Characteristic curves and envelope curves are plotted. The latter are an interesting tool from which the characteristic dimensions of the ejector can be rapidly obtained for preliminary dimensioning (for an initial contact with a customer for example). These ejectors, which were specifically designed for the process rather than selected from a catalog of standard devices, will promote energy saving.
entropy-14-00599.pdf (363.15 Ko) Télécharger le fichier
Origine : Publication financée par une institution
licence : CC BY - Paternité
hal-01529405 , version 1 (04-09-2023)
Paternité
Yveline Marnier Antonio, Christelle Périlhon, Georges Descombes, Claude Chacoux. Thermodynamic Modelling of an Ejector with Compressible Flow by a One-Dimensional Approach. Entropy, 2012, 14 (4), pp.599--613. ⟨10.3390/e14040599⟩. ⟨hal-01529405⟩
105 Consultations
66 Téléchargements
