LES OUTILS DE GESTION, TRANSPORTEURS ET RÉGULATEURS DES LOGIQUES INSTITUTIONNELLES Cas de deux organisations de capital-risque solidaire - CV des membres de IRG Accéder directement au contenu
Thèse Année : 2013
MANAGEMENT ARTIFACTS AS CARRIERS AND REGULATORS OF INSTITUTIONAL LOGICS Two case studies of venture capital funds solidarity-oriented
Institutional theory describes management artifacts as embedded in the society and in interactions with organizational actors. This work is aiming to grasp the complexity of management apparatus and analyzes it as: first, symbolical element neutral for the organizational activity, adopted for legitimacy and diffused by isomorphic mechanisms; then, rhetorical objects generating languages and categorizations, transformed by actors; finally, as artifacts carrying multiple institutional logics. This thesis postulates that management artifacts can also regulate contradictions between institutional logics. A qualitative methodology combining longitudinal multi-level approaches and research action, is revealing the institutional logics of the organizational field of interdependent finance and of two interdependent venture capital funds. The management apparatus of these funds is studied. New management tools created during the research action, charters and shareholders' agreements are carrying venture organizations' institutional logics. A change in a shareholders' agreement and the management system of the investment decision-making process in a venture fund, named investment committees, divulge that management apparatus handle tensions between institutional logics by eliminating one of them, compartmenting or integrating them. The results of this study acknowledge different degrees in the contradictions between institutional logics related to their permeability, the professions represented in the organization, the practices looked at. They contribute also to formalize links between management artifacts and institutional logics. We lastly propose a model combining two processes that explicate how multiple logics can blend and how tensions can be handled.
La théorie néo institutionnelle permet de penser les outils de gestion dans la société et dans l'interaction avec les acteurs des organisations. Ce travail montre la complexité des instruments de gestion et les envisage tour à tour comme : des éléments symboliques neutres à l'activité de l'organisation adoptés par souci de légitimité et diffusés par des mécanismes isomorphiques, des objets rhétoriques générateurs de langage et de catégorisations et transformés par les acteurs organisationnels, des artefacts transportant des logiques institutionnelles multiples naissant dans le champ organisationnel. Cette thèse pose l'existence d'un nouveau rôle pour les outils de gestion, celui de régulateur des contradictions entre logiques institutionnelles. Sur le plan empirique, avec une méthodologie qualitative mêlant approches longitudinales multi niveaux et recherche intervention, nous avons analysé les logiques institutionnelles du champ de la finance solidaire en France et de deux organisations de capital-risque solidaire. Les outils de gestion de ces deux organisations sont ensuite étudiés. Les outils créés avec le chercheur, les pactes d'actionnaires et les chartes, véhiculent les logiques institutionnelles des fonds. Le changement des pactes d'actionnaires et les comités d'investissement permettent de révéler que les outils de gestion gèrent les tensions entre logiques institutionnelles en les éliminant, les compartimentant ou les intégrant. Les résultats de cette étude autorisent une discussion sur le degré d'incompatibilité entre les logiques en fonction de leur perméabilité, des métiers représentés dans les organisations et des pratiques considérées. Nous présentons également une formalisation des liens entre outils de gestion et logiques institutionnelles ainsi qu'entre logiques institutionnelles présentes dans l'organisation et rôle des outils de gestion. Enfin, nous proposons un process socio technique d'hybridation de logiques institutionnelles.
thA_se_p_chateau_terrisse_vfas.pdf (6.13 Mo) Télécharger le fichier
tel-00943599 , version 1 (07-02-2014)
tel-00943599 , version 2 (24-06-2014)
  • HAL Id : tel-00943599 , version 1
Pascale Chateau Terrisse. LES OUTILS DE GESTION, TRANSPORTEURS ET RÉGULATEURS DES LOGIQUES INSTITUTIONNELLES Cas de deux organisations de capital-risque solidaire. Gestion et management. Université de Marne la Vallée, 2013. Français. ⟨NNT : ⟩. ⟨tel-00943599v1⟩
908 Consultations
2808 Téléchargements
