No evidence of an immune adjustment in response to a parasitoid threat in Lobesia botrana larvae. - ECO/EVO Accéder directement au contenu
Article Dans Une Revue Journal of Insect Physiology Année : 2017
Immune function is a key determinant of an organism's fitness, and natural insect populations are highly variable for this trait, mainly due to environmental heterogeneity and pathogen diversity. We previously reported a positive correlation between infection prevalence by parasitoids and host immunity in natural populations of the vineyard pest Lobesia botrana. Here, we tested whether this correlation reflects a plastic adjustment of host immunity in response to the local presence of parasites. To this end, we measured immunity of non-parasitized L. botrana larvae exposed, respectively, to one of the two most common species of parasitoids in vineyards, over 6days. Larvae were able to sense the parasitoid through visual, chemical, or mechanical cues, but contact larvae-parasitoid were excluded. Contrary to our hypothesis, we found that L. botrana larvae did not increase their immune defenses in the presence of parasitoids, despite their ability to sense a potential threat. Our results therefore suggest that the positive correlation between infection prevalence by parasitoids and L. botrana immunity among natural populations may result from micro-evolutionary changes resulting from long-term local selection pressures imposed by parasitoids in wild populations rather than plastic adjustments of immunity.
Vogelweith et al. Main document 2nd revision.pdf (370.3 Ko) Télécharger le fichier
licence : CC BY NC - Paternité - Pas d'utilisation commerciale
hal-01581100 , version 1 (24-02-2024)
Paternité - Partage selon les Conditions Initiales
Fanny Vogelweith, Yannick Moret, Denis Thiéry, Lionel Delbac, Jérôme Moreau. No evidence of an immune adjustment in response to a parasitoid threat in Lobesia botrana larvae.. Journal of Insect Physiology, 2017, 102, pp.7-11. ⟨10.1016/j.jinsphys.2017.08.010⟩. ⟨hal-01581100⟩
77 Consultations
2 Téléchargements
