Dynamics of Viral Abundance and Diversity in a Sphagnum-Dominated Peatland: Temporal Fluctuations Prevail Over Habitat - Rôle de la Biodiversité dans les Processus Ecologiques Accéder directement au contenu
Article Dans Une Revue Frontiers in Microbiology Année : 2016
Viruses impact microbial activity and carbon cycling in various environments, but their diversity and ecological importance in Sphagnum-peatlands are unknown. Abundances of viral particles and prokaryotes were monitored bi-monthly at a fen and a bog at two different layers of the peat surface. Viral particle abundance ranged from 1.7 x 10(6) to 5.6 x 10(8) particles mL(-1), and did not differ between fen and bog but showed seasonal fluctuations. These fluctuations were positively correlated with prokaryote abundance and dissolved organic carbon, and negatively correlated with water-table height and dissolved oxygen. Using shotgun metagenomics we observed a shift in viral diversity between winter/spring and summer/autumn, indicating a seasonal succession of viral communities, mainly driven by weather-related environmental changes. Based on the seasonal asynchrony between viral and microbial diversity, we hypothesize a seasonal shift in the active microbial communities associated with a shift from lysogenic to lytic lifestyles. Our results suggest that temporal variations of environmental conditions rather than current habitat differences control the dynamics of virus-host interactions in Sphagnum-dominated peatlands
fmicb-06-01494.pdf (1.84 Mo) Télécharger le fichier
hal-01263117 , version 1 (10-07-2022)
Paternité
Flore Ballaud, Alexis Dufresne, Andre-Jean Francez, Jonathan Colombet, Télesphore Sime-Ngando, et al.. Dynamics of Viral Abundance and Diversity in a Sphagnum-Dominated Peatland: Temporal Fluctuations Prevail Over Habitat. Frontiers in Microbiology, 2016, 6, pp.1494. ⟨10.3389/fmicb.2015.01494⟩. ⟨hal-01263117⟩
154 Consultations
19 Téléchargements
