Responses of a tropical micro-crustacean, Daphnia lumholtzi, upon exposures to dissolved toxins and living cells of cyanobacteria - Rôle de la Biodiversité dans les Processus Ecologiques Accéder directement au contenu
Article Dans Une Revue Environmental Technology and Innovation Année : 2020
The mass development and expansion of cyanobacteria release cyanotoxins in the aquatic environment and cause serious problems for grazers such as micro-zooplankton. In contrast to aquatic ecosystems in temperate regions, impacts of cyanobacteria and their toxins on tropical micro-crustaceans are relatively understudied. In this study, acute and chronic effects of pure microcystin-LR (MC-LR), a crude extract of water bloom sample with a dominance of Microcystis aeruginosa containing microcystins (MCE) and living cells of Cylindrospermopsis curvispora were tested on a tropical micro-crustacean, Daphnia lumholtzi. The 24 h- and 48 h-LC50 values for MC-LR ranged from 247–299, and 331–409 μg MCE L−1, respectively. Exposures to 1–25 μg MCE L−1 decreased survival, fecundity, and reproduction of D. lumholtzi. The impacts of C. curvispora cells on life-history traits of D. lumholtzi were density-dependent and more severe than the impacts of dissolved microcystins. It could be that the adverse effects of C. curvispora on D. lumholtzi are linked to a combination of potential toxic metabolites, mal-nutrients, feeding and swimming interference. Daphnia lumholtzi used in this study is more sensitive to microcystins compared to Daphnia species from temperate regions. Therefore, we highly suggest using D. lumholtzi as a model species for toxicity testing and monitoring on water quality, particularly in tropical countries.
Vo et al EnvTechIn 2020.pdf (1.26 Mo) Télécharger le fichier
hal-04017950 , version 1 (26-08-2020)
hal-04017950 , version 2 (07-03-2023)
Thi-My-Chi Vo, Ba-Trung Bui, Claudia Wiegand, Khuong V Dinh, Thanh-Son Dao. Responses of a tropical micro-crustacean, Daphnia lumholtzi, upon exposures to dissolved toxins and living cells of cyanobacteria. Environmental Technology and Innovation, 2020, 19, ⟨10.1016/j.eti.2020.100973⟩. ⟨hal-04017950v2⟩
126 Consultations
166 Téléchargements
