Pour une géographie de la gestion de crise : de l'accessibilité aux soins d'urgence à la vulnérabilité du territoire à Lima - Équipe III : RESSOURCES PATRIMONIALES, VULNERABILITES ET RECOMPOSITION DES TERRITOIRES DE MONTAGNE Accéder directement au contenu
Thèse Année : 2012
For a geography of crisis management : accessibility to emergency healthcare and vulnerability of the territory in Lima
The urban area of Lima and Callao (9 million inhabitants) is preparing for an earthquake of great magnitude that could entail a major crisis. In front of this coming crisis, what do we know about the vulnerability of this urban territory? This research study suggests putting the milestones of a geography of crisis management based on the accessibility to emergency healthcare in Lima and Callao. It is an urban geography located at the crossroads of risk, crisis and emergency health issues, which directly tackles the spatial and territorial dimensions of crisis management. This research study is based on a panorama of big urban crises and presents a critical analysis of the paradigms of risk and crises. This innovative geographical approach aims at seizing both the complexity of crisis situations and the vulnerability of big urban areas. Since crisis management aims at putting in relation the resources that are useful at the moment of the event with the vulnerable spaces that need to be helped first, a georeferenced database of emergency health resources in Lima enables the analysis of the spatial and territorial dimensions of crisis management. Different vulnerabilities are evidenced, such as those of the major hospitals, of the healthcare system and of the population through the accessibility to health facilities in a crisis situation. Each and all of them contributes to understand the vulnerability of the territory. Thus, this research study considers crisis management as an object of research inside geography, since it helps answering urban problems beyond the concerns of risks and crises. It also suggests working out the issue of vulnerability thanks to a joint understanding of the spatial and territorial dimensions of crisis management at the time of the event and during the building process of the city on the long term. This geography of crisis overtakes the cleavage between risk prevention and preparation for crisis management by being part of a risk / crisis continuum, and reintroduces territory and politics at the heart of risks and crises issues in urban areas.
La aglomeración urbana de Lima y Callao (9 millones de habitantes) se prepara a un sismo de gran magnitud susceptible de provocar una crisis mayor. Frente a esta crisis por venir, ¿qué conocimientos se pueden producir sobre la vulnerabilidad del territorio urbano? Esta investigación propone iniciar una geografía de la gestión de crisis a partir de la cuestión de la atención médica en Lima y Callao. Es una geografía urbana situada entre las problemáticas del riesgo, de la crisis y de la salud de emergencia, que abarca frontalmente las dimensiones espaciales y territoriales de la gestión de crisis.La problemática de investigación se apoya en un panorama de grandes crisis urbanas y promueve un análisis crítico de los paradigmas de gestión de los riesgos y de las crisis. De forma innovadora, este enfoque geográfico considera conjuntamente la complejidad de las situaciones de crisis y la vulnerabilidad de las grandes aglomeraciones urbanas. Con la idea de que la gestión de crisis consiste en relacionar los recursos útiles al momento del evento y los espacios vulnerables a socorrer prioritariamente, se recurre a una base de datos georeferenciada de los recursos de atención médica de emergencia en Lima para analizar las dimensiones espaciales y territoriales de la gestión de crisis. Diferentes vulnerabilidades son puestas en evidencia: la de los hospitales esenciales, la del sistema de salud y la de la población, a través de la accesibilidad a la atención de salud en situación de crisis.Así, esta investigación propone la gestión de crisis como un verdadero objeto de investigación de la geografía, capaz de vislumbrar las cuestiones urbanas más allá de la problemática del riesgo y la crisis. Plantea una comprensión de la vulnerabilidad a partir de una lectura conjunta de las dimensiones espaciales y territoriales de la gestión de crisis al momento del evento y de los procesos de construcción de la ciudad a largo tiempo. Esta geografía de la crisis va más allá de la segmentación entre la prevención de los riesgos y la preparación para el manejo de emergencia, inscribiéndose en un continuum riesgo / crisis, y reintroduce el territorio y el político como elementos claves de la problemática de los riesgos y de las crisis en medio urbano.
L'agglomération urbaine de Lima et Callao (9 millions d'habitants) se prépare à un séisme de grande magnitude susceptible de provoquer une crise majeure. Face à cette crise à venir, quelles connaissances peut-on produire sur la vulnérabilité du territoire urbain ? Cette recherche propose de poser les jalons d'une géographie de la gestion de crise à partir de la question de l'accessibilité aux soins à Lima et Callao. C'est une géographie urbaine à la croisée des problématiques du risque, de la crise et de la santé d'urgence, qui aborde frontalement les dimensions spatiales et territoriales de la gestion des situations de crise. La problématique de recherche s'appuie sur un panorama de grandes crises urbaines et propose une analyse critique des paradigmes de gestion des risques et des crises. Innovante, cette approche géographique impose de saisir conjointement la complexité des situations de crises et la vulnérabilité des grandes agglomérations urbaines. Partant de l'idée que la gestion de crise consiste à mettre en relation des ressources utiles au moment de l'évènement et des espaces vulnérables à secourir en priorité, une base de données géoréférencées des ressources de santé d'urgence à Lima a été construite et utilisée pour analyser les dimensions spatiales et territoriales de la gestion de crise. Différentes vulnérabilités sont mises en évidence : celles des hôpitaux majeurs, celles du dispositif de soins, et celles de la population à travers l'accessibilité aux soins en situation de crise. Elles contribuent toutes à la compréhension de la vulnérabilité du territoire. Ainsi, cette recherche propose de faire de la gestion de crise un véritable objet de recherche de la géographie, capable d'éclairer les questions urbaines au-delà de la problématique des risques et des crises. Elle propose de décrypter la vulnérabilité à partir d'une lecture conjointe des dimensions spatiales et territoriales de la gestion de crise au moment de l'événement et des processus de construction de la ville sur le temps long. Cette géographie de la crise dépasse le clivage entre prévention des risques et préparation à la gestion de crise en s'inscrivant dans un continuum risque / crise, et réintroduit le territoire et le politique au cœur de la problématique des risques et des crises en milieu urbain.
35629_ROBERT_2012_archivage.pdf (32.53 Mo) Télécharger le fichier
tel-00766252 , version 1 (17-12-2012)
tel-00766252 , version 2 (23-01-2013)
  • HAL Id : tel-00766252 , version 2
Jérémy Robert. Pour une géographie de la gestion de crise : de l'accessibilité aux soins d'urgence à la vulnérabilité du territoire à Lima. Histoire. Université de Grenoble, 2012. Français. ⟨NNT : 2012GRENA027⟩. ⟨tel-00766252v2⟩
1580 Consultations
2222 Téléchargements
