3D numerical modelling of dune formation and dynamics in inland waterways - Laboratoire d'Hydraulique Saint-Venant Accéder directement au contenu
Thèse Année : 2016
Modélisation numérique 3D de la formation et de la dynamique de dunes au sein des voies navigables
In this work the possibilities of direct modelling of large scale bed forms in waterways are highlighted and analysed. It is motivated by the fact that in river modelling, uncertainties in predicting water depth and bed movement can often be attributed to bed forms. Those bed forms are the dominating factor for bed load transport in many river stretches, which need to be maintained by the responsible waterways authorities.Hydrodynamic and morphodynamic experiments have been conducted at the Federal Waterways Engineering and Research Institute of Germany (BAW). High-resolution measurements have been performed over fixed, naturally formed three-dimensional sand dunes, which are at equilibrium with the surrounding flow field.Using these measured data sets, the hydrodynamic model is calibrated to simulate the complex flow situation over a train of several three-dimensional dunes. Simulation results show that it is possible to reproduce the measured turbulent flow field in the wake of the fixed dunes and that the measured and simulated water levels agree for the chosen configuration. Vertical and horizontal mesh resolution, friction coefficient, small scale bed forms and turbulence modelling are identified as most sensitive parameters during the calibration.The second part of this thesis focuses on morphodynamic simulations of the same experimental flume but with a mobile bed. High resolution measured bottom scans of the dune forms, developing over time, are available for comparison. Dune height and length, as well as the distribution moments, skewness and kurtosis are used to compare the dimensions of the dunes and also their shape and spatial distribution.Bed load transport formulation, skewness and kurtosis formulae, boundary conditions and the consideration of sub-grid scale roughness elements are the parameters which influence the quality of the results the most. A particular focus during the study is the inclusion of turbulent fluctuations in bed shear stress calculation. A new, total bed shear stress calculation is proposed, which incorporates mean flow velocities and turbulent kinetic energy provided by the turbulence model. With this approach, the numerical model is able to reproduce both qualitatively and quantitatively the measured mean bed forms dimensions and the shape moments of the physical dunes. It proves to be the only way to also produce the right distribution moment (kurtosis) of the dune field.Finally, the model is applied to project scale and tested on a stretch of the riverElbe, Germany. High resolution morphodynamic simulations coupled to 3D-hydrodynamics are conducted over several days for the chosen river stretch which is 4km in length. The dune forms preserve form and shape parameters and the dune speed agrees with the measured one. The simulations show promising results concerning the possibility of operational use of the model in the future. Local problems and statements, e.g. maintenance strategies such as changes in flow cross section, groynes and revetments, are possible tasks that can be examined
Ce rapport présente et analyse les différentes possibilités de modélisation directe et de grande envergure de la forme du fond des voies naviguables. Cette étude est motivée par le fait que dans la modélisation de rivière, les incertitudes quant à la prédiction de la profondeur et du mouvement du lit, peuvent souvent être affectées par sa forme. La forme du fond constitue le facteur dominant dans le transport solide de nombreux cours d´eau qui nécessitent donc d´être entretenus par les autorités compétantes.Des expériences hydrodynamiques et morphodynamiques ont été menées au sein de l´institut fédéral allemand de la recherche et de l´ingénieurie des cours d´eau (BAW). Des mesures en haute résolution ont été effectuées et ont révélé la formation naturelle de dunes tridimensionelles à l´équilibre avec le champ d´écoulement environnant. Le modèle hydrodynamique est calibré sur cette base de données pour modéliser le régime d´écoulement complexe à travers une suite de dunes tridimensionelles. Les résultats de la simulation montrent qu´il est possible de reproduire le champ d´écoulement turbulent mesuré dans la configuration précédemment citée et que le niveau d´eau mesuré et simulé est également en accord avec cette même configuration. La résolution verticale et horizontale du maillage, le coefficient de friction, la forme du lit à petite échelle et la modélisation turbulente sont identifiés comme paramètres sensibles durant le calibrage.La seconde partie de cette thèse se concentre sur les simulations morphodynamiques de ce même canal expérimental mais cette fois avec un lit mobile. La numérisation du fond mesuré en haute résolution montrant la formation et le développement des dunes au fil du temps, est mis à disposition pour la comparaison. La hauteur et la largeur des dunes tout comme le moment de distribution, l´inclinaison et l´aplatissement sont utilisés pour comparer les dimensions des dunes ainsi que leur forme et leur distribution spatiale. Les formules du transport solide, de l´inclinaison, de l´aplatissement, les conditions aux limites et la considération des éléments de rugosité de sous échelle sont les paramètres qui influencent le plus la qualité des résultats. Durant cette étude, une attention toute particulière a été portée sur l´intégration des fluctuations turbulentes dans le calcul de la contrainte de cisaillement du fond. Un nouveau calcul total de cette contrainte est proposé et incorpore les vitesses d´écoulement principales et l´énergie cinétique turbulente fournit par le modèle turbulent. Grâce à cette approche, le modèle numérique est capable de reproduire quantitativement et qualitativement les dimensions de la forme du lit principal mesurée et les moments de forme des dunes physiques. Cela s´avère être la seule façon de reproduire le bon moment de distribution (aplatissement) du champ de dunes.Finalement, le modèle est appliqué à l´échelle du projet et testé sur une portion de l´Elbe (Allemagne). Les simulations morphodynamiques en haute résolution couplées à l´hydrodynamique-3D sont menées durant plusieurs jours sur la portion de rivière choisit d´une longueur de 4 kilomètres. Les formes des dunes préservent les paramètres de forme et la vitesse des dunes est en accord avec celle mesurée. La simulation montre des résultats prométeurs concernant la possibilité d´un usage opérationel du modèle dans l´avenir. Des problèmes locaux et communs comme les stratégies d´entretien tel que les changements dans les sections transversales d´écoulement, les brises lames et le revêtement sont des missions possibles qui peuvent être examinées
TH2016PESC1119_complete.pdf (48.06 Mo) Télécharger le fichier
Origine Version validée par le jury (STAR)
tel-01542852 , version 1 (20-06-2017)
  • HAL Id : tel-01542852 , version 1
Annalena Goll. 3D numerical modelling of dune formation and dynamics in inland waterways. Fluid mechanics [physics.class-ph]. Université Paris-Est, 2016. English. ⟨NNT : 2016PESC1119⟩. ⟨tel-01542852⟩
514 Consultations
63 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
