Conceptual and Technical Challenges for High Performance Computing
High Performance Computing (HPC) aims at providing reasonably fast computing solutions to scientific and real life problems. Many efforts have been made on the way to powerful supercomputers, including generic and customized configurations. The advent of multicore architectures is noticeable in the HPC history, because it has brought the underlying parallel programming concept into common considerations. At a larger scale, there is a keen interest in building or hosting frontline supercomputers; the Top500 ranking is a nice illustration of this (implicit) racing. Supercomputers, as well as ordinary computers, have fallen in price for years while gaining processing power. We clearly see that, what commonly springs up in mind when it comes to HPC is computer capability. However, when going deeper into the topic, especially on large-scale problems, it appears that the processing speed by itself is no longer sufficient. Indeed, the real concern of HPC users is the time-to-output. Thus, we need to study each important aspect in the critical path between inputs and outputs. The first step is clearly the method, which is a conjunction of modelling with specific considerations (hypothesis, simplifications, constraints, to name a few) and a corresponding algorithm, which could be numerical and/or non numerical. Then comes the topic of programming, which should yield a skillful mapping of the algorithm onto HPC machines. Based on multicore processors, probably enhanced with acceleration units, current generation of supercomputers is rated to deliver an increasing peak performance, the Exascale era being the current horizon. However, getting a high fraction of the available peak performance is more and more difficult. The Design of an efficient code that scales well on a supercomputer is a non-trivial task. Manycore processors are now common, and the scalability issue in this context is crucial. Code optimization requires advanced programming techniques, taking into account the specificities and constraints of the target architecture. Many challenges are to be considered from the standpoint of efficiency and expected performances. The present chapter will discuss the aforementioned points, interleaved with commented contributions from the literature and our personal views.
