Study of the capabilities of an ALE bi-material fluid simulation for solving cavity expansion and collapse during an Hydrodynamic Ram event - Laboratoire brestois de mécanique et des systèmes Accéder directement au contenu
Thomas Fourest
  • Fonction : Auteur
  • PersonId : 1095121
Jean-Marc Laurens
  • Fonction : Auteur
M. Arrigoni
The hydrodynamic ram phenomenon generally referred to as HRAM, constitutes an important threat to modern aircraft, especially lightweight aircraft such as UAV that cannot be armoured due to the weight penalty. The aim of the present feasibility study is to determine whether an ALE solver using bi-material fluid permits a qualitative simulation of all the phases of the HRAM event, in particular the oscillations (growth and collapse) of the cavity created during the impact of a non-trivial geometry high speed projectile on a water filled tank. The present study examines the closure of the wake cavity, its shape and the deceleration of the projectile.
a_7TW350U2.pdf (264.68 Ko) Télécharger le fichier
hal-01717089 , version 1 (25-02-2018)
Domaine public
  • HAL Id : hal-01717089 , version 1
Thomas Fourest, Jacques Dupas, Eric Deletombe, Jean-Marc Laurens, M. Arrigoni. Study of the capabilities of an ALE bi-material fluid simulation for solving cavity expansion and collapse during an Hydrodynamic Ram event. 11e colloque national en calcul des structures, CSMA, May 2013, Giens, France. ⟨hal-01717089⟩
248 Consultations
43 Téléchargements
