Estimating Fatigue Life of Carbon-Epoxy Composites: A Rapid Method coupling Thermo-Mechanical Analysis and Residual Strength - Département Mécanique Accéder directement au contenu
Article Dans Une Revue (Data Paper) Fatigue and Fracture of Engineering Materials and Structures Année : 2024
The investigation of fatigue behavior typically in time-consuming tests, leading some re to explore ologies based on self-heating tests to reduce the process. For composite materials, the conventional ap in piecewise linear approximations of the self-heating curve and the stress transition between the first and second is arbitrarily associated with a fatigue lifetime equal to 106 cycles. This paper proposes a novel ology to address these sim- plifications. First, a non-linear vis tic is used to de the self-heating on the mechanisms estab in the literature, a link is proposed between the dissipation and the fatigue limit. The load leading to a significant con- tribution of non-linear mecha is associated with an infinite life time. It allows the identification of an S-N curve and prediction of fatigue behavior a min- imal number of tests. The comparison with fatigue results is satisfactory.
Fichier sous embargo
0 3 3
Année Mois Jours
Avant la publication
samedi 10 août 2024
samedi 10 août 2024
Connectez-vous pour demander l'accès au fichier
hal-04450334 , version 1 (10-02-2024)
Kilian Demilly, Jeanne Cavoit, Yann Marco, Gurvan Moreau, Guillaume Dolo, et al.. Estimating Fatigue Life of Carbon-Epoxy Composites: A Rapid Method coupling Thermo-Mechanical Analysis and Residual Strength. Fatigue and Fracture of Engineering Materials and Structures, inPress, ⟨10.1111/ffe.14254⟩. ⟨hal-04450334⟩
25 Consultations
5 Téléchargements
