Trajectory Optimization for Fully Actuated Hexacopters : Enhancing Maneuverability and Applications - PCGN : Pilotage, Commande, Guidage et Navigation robustes et sûres Accéder directement au contenu
Mohamad Hachem
  • Fonction : Auteur
  • PersonId : 1287730
Thierry Miquel
Murat Bronz
Clément Roos
  • Fonction : Auteur
  • PersonId : 1063475
Trajectory optimization is a challenging task in the robotics community. Several factors need to be taken into account when generating a feasible optimized trajectory. The optimization process heavily relies on the dynamic model of the system. Currently, there are various drone designs available, categorized based on their actuation status. In this study, we apply a trajectory optimization technique to a fully actuated hexacopter (FA-Hex), which is a new application to the best of our knowledge. This type of vehicle has been successfully integrated into several practical applications. Unlike the under-actuated hexacopter (UA-Hex), the FA-Hex can perform maneuvers with minimal banking angles, significantly enhancing the drone's maneuverability. Our research focuses specifically on trajectory optimization for the FA-Hex and demonstrates the adaptability of our method to different scenarios. We discuss two specific applications: a drone filming without a gimbal joint and a drone with a cable-suspended pendulum. We compare the simulation results with the UA-Hex model to highlight the differences in maneuverability between the two systems. The trajectory optimization is performed offline using CasADi in the MATLAB framework.
Mots clés
TrajectoryOptimizationFullyActuatedHexacopters_IMAV2023-28.pdf (799.67 Ko) Télécharger le fichier
hal-04396701 , version 1 (16-01-2024)
  • HAL Id : hal-04396701 , version 1
Mohamad Hachem, Thierry Miquel, Murat Bronz, Clément Roos. Trajectory Optimization for Fully Actuated Hexacopters : Enhancing Maneuverability and Applications. 14th ANNUAL INTERNATIONAL MICRO AIR VEHICLE CONFERENCE AND COMPETITION, Sep 2023, Aachen, Germany. ⟨hal-04396701⟩
84 Consultations
65 Téléchargements
