Linear stability analysis on a laminar separation bubble subjected to freestream turbulence - Archive ouverte HAL Accéder directement au contenu
Boundary layer measurements using hotwire anemometry are employed to study the flow development of a laminar separation bubble (LSB) over the suction side of a NACA0015 aerofoil, at a chord based Reynolds number of 125000 fixed and at an angle of incidence of 2.3 degrees, in a open circuit wind tunnel subjected to a wide range of turbulence intensity (0.15% < Tu < 6.26%). A Local linear stability analysis (LST) is conducted on experimental boundary layer profiles in the fore position of the LSB.
DMPE22027.1646229458.pdf (541.23 Ko) Télécharger le fichier
hal-03773978 , version 1 (09-09-2022)
  • HAL Id : hal-03773978 , version 1
Thomas Jaroslawski, Maxime Forte, Olivier Vermeersch, Erwin Gowree, Jean-Marc Moschetta. Linear stability analysis on a laminar separation bubble subjected to freestream turbulence. 14th ERCOFTAC SIG 33 Workshop, Progress in Flow Instability, Transition and Control, Jun 2022, Cadiz, Spain. ⟨hal-03773978⟩
9 Consultations
8 Téléchargements
