Spectral Variability in Hyperspectral Data Unmixing: A Comprehensive Review - VIBS Accéder directement au contenu
Article Dans Une Revue IEEE geoscience and remote sensing magazine Année : 2021
The final version of this paper can be found in the IEEE Geoscience and Remote Sensing Magazine. The spectral signatures of the materials contained in hyperspectral images, also called endmembers (EM), can be significantly affected by variations in atmospheric, illumination or environmental conditions typically occurring within an image. Traditional spectral unmixing (SU) algorithms neglect the spectral variability of the endmembers, what propagates significant mismodeling errors throughout the whole unmixing process and compromises the quality of its results. Therefore, large efforts have been recently dedicated to mitigate the effects of spectral variability in SU. This resulted in the development of algorithms that incorporate different strategies to allow the EMs to vary within a hyperspectral image, using, for instance, sets of spectral signatures known a priori, Bayesian, parametric, or local EM models. Each of these approaches has different characteristics and underlying motivations. This paper presents a comprehensive literature review contextualizing both classic and recent approaches to solve this problem. We give a detailed evaluation of the sources of spectral variability and their effect in image spectra. Furthermore, we propose a new taxonomy that organizes existing works according to a practitioner's point of view, based on the necessary amount of supervision and on the computational cost they require. We also review methods used to construct spectral libraries (which are required by many SU techniques) based on the observed hyperspectral image, as well as algorithms for library augmentation and reduction. Finally, we conclude the paper with some discussions and an outline of possible future directions for the field.
2001.07307.pdf (10.33 Mo) Télécharger le fichier
hal-03265014 , version 1 (18-06-2021)
Ricardo Augusto Borsoi, Tales Imbiriba, Jose Carlos Bermudez, Cédric Richard, Jocelyn Chanussot, et al.. Spectral Variability in Hyperspectral Data Unmixing: A Comprehensive Review. IEEE geoscience and remote sensing magazine, 2021, 9 (4), pp.223-270. ⟨10.1109/mgrs.2021.3071158⟩. ⟨hal-03265014⟩
269 Consultations
214 Téléchargements
