Assembly of The Mitochondrial Complex I Assembly Complex Suggests a Regulatory Role for Deflavination - Groupe Imagerie microscopique d'assemblages complexes / Microscopic Imaging of complex Assemblies group (IBS-MICA) Accéder directement au contenu
Article Dans Une Revue Angewandte Chemie International Edition Année : 2020
Matthew Jessop
Luca Signor
Adrien Favier
Darren Hart
Irina Gutsche
Fatty acid β-oxidation (FAO) and oxidative phosphorylation (OXPHOS) are mitochondrial redox processes that generate ATP. The biogenesis of the respiratory Complex I, a 1 MDa multiprotein complex that is responsible for initiating OXPHOS, is mediated by assembly factors including the mitochondrial complex I assembly (MCIA) complex. However, the organisation and the role of the MCIA complex are still unclear. Here we show that ECSIT functions as the bridging node of the MCIA core complex. Furthermore, cryo-electron microscopy together with biochemical and biophysical experiments reveal that the C-terminal domain of ECSIT directly binds to the vestigial dehydrogenase domain of the FAO enzyme ACAD9 and induces its deflavination, switching ACAD9 from its role in FAO to an MCIA factor. These findings provide the structural basis for the MCIA complex architecture and suggest a unique molecular mechanism for coordinating the regulation of the FAO and OXPHOS pathways to ensure an efficient energy production.
Giachin et al. - 2021 - Assembly of The Mitochondrial Complex I Assembly C.pdf (2.32 Mo) Télécharger le fichier
Origine Fichiers éditeurs autorisés sur une archive ouverte
hal-03119718 , version 1 (25-11-2021)
Gabriele Giachin, Matthew Jessop, Romain Bouverot, Samira Acajjaoui, Melissa Saïdi, et al.. Assembly of The Mitochondrial Complex I Assembly Complex Suggests a Regulatory Role for Deflavination. Angewandte Chemie International Edition, 2020, ⟨10.1002/anie.202011548⟩. ⟨hal-03119718⟩
150 Consultations
66 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
