A Unified Description of Intrinsically Disordered Protein Dynamics under Physiological Conditions Using NMR Spectroscopy - Groupe Transporteurs Membranaires / Membrane Transporters Group (IBS-MEMBRANE) Accéder directement au contenu
Article Dans Une Revue Journal of the American Chemical Society Année : 2019
Intrinsically disordered proteins (IDPs) are flexible biomolecules whose essential functions are defined by their dynamic nature. Nuclear magnetic resonance (NMR) spectroscopy is ideally suited to the investigation of this behavior at atomic resolution. NMR relaxation is increasingly used to detect conformational dynamics in free and bound forms of IDPs under conditions approaching physiological, although a general framework providing a quantitative interpretation of these exquisitely sensitive probes as a function of experimental conditions is still lacking. Here, measuring an extensive set of relaxation rates sampling multiple-time-scale dynamics over a broad range of crowding conditions, we develop and test an integrated analytical description that accurately portrays the motion of IDPs as a function of the intrinsic properties of the crowded molecular environment. In particular we observe a strong dependence of both short-range and long-range motional time scales of the protein on the friction of the solvent. This tight coupling between the dynamic behavior of the IDP and its environment allows us to develop analytical expressions for protein motions and NMR relaxation properties that can be accurately applied over a vast range of experimental conditions. This unified dynamic description provides new insight into the physical behavior of IDPs, extending our ability to quantitatively investigate their conformational dynamics under complex environmental conditions, and accurately predicting relaxation rates reporting on motions on time scales up to tens of nanoseconds, both in vitro and in cellulo.
Adamski et al. J Am Chem Soc.pdf (4.12 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-02414561 , version 1 (23-11-2020)
Wiktor Adamski, Nicola Salvi, Damien Maurin, Justine Magnat, Sigrid Milles, et al.. A Unified Description of Intrinsically Disordered Protein Dynamics under Physiological Conditions Using NMR Spectroscopy. Journal of the American Chemical Society, 2019, 141 (44), pp.17817-17829. ⟨10.1021/jacs.9b09002⟩. ⟨hal-02414561⟩
157 Consultations
418 Téléchargements
