Kalikow decomposition for counting processes with stochastic intensity * - IDEX UCA JEDI Université Côte d'Azur Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Tien Cuong Phi
  • Fonction : Auteur
  • PersonId : 1056389
We propose a new Kalikow decomposition and the corresponding Perfect Simulation algorithm for continuous time multivariate counting processes, on potentially infinite networks. We prove the existence of such a decomposition in various cases. This decomposition is not unique and we discuss the choice of the decomposition in terms of algorithmic efficiency. We apply these methods on several examples: linear Hawkes process, age dependent Hawkes process, exponential Hawkes process.
Arxiv_Kalikow_decomposition_for_counting_processes_with_stochastic_intensity.pdf (434.18 Ko) Télécharger le fichier
hal-03188536 , version 1 (02-04-2021)
hal-03188536 , version 2 (02-05-2022)
  • HAL Id : hal-03188536 , version 1
Tien Cuong Phi. Kalikow decomposition for counting processes with stochastic intensity *. 2021. ⟨hal-03188536v1⟩
192 Consultations
109 Téléchargements
