Robust Bayesian fusion of continuous segmentation maps - IDEX UCA JEDI Université Côte d'Azur Accéder directement au contenu
Article Dans Une Revue Medical Image Analysis Année : 2022
The fusion of probability maps is required when trying to analyse a collection of image labels or probability maps produced by several segmentation algorithms or human raters. The challenge is to weight the combination of maps correctly, in order to reflect the agreement among raters, the presence of outliers and the spatial uncertainty in the consensus. In this paper, we address several shortcomings of prior work in continuous label fusion. We introduce a novel approach to jointly estimate a reliable consensus map and to assess the presence of outliers and the confidence in each rater. Our robust approach is based on heavy-tailed distributions allowing local estimates of raters performances. In particular, we investigate the Laplace, the Student’s t and the generalized double Pareto distributions, and compare them with respect to the classical Gaussian likelihood used in prior works. We unify these distributions into a common tractable inference scheme based on variational calculus and scale mixture representations. Moreover, the introduction of bias and spatial priors leads to proper rater bias estimates and control over the smoothness of the consensus map. Finally, we propose an approach that clusters raters based on variational boosting, and thus may produce several alternative consensus maps. Our approach was successfully tested on MR prostate delineations and on lung nodule segmentations from the LIDC-IDRI dataset.
manuscript.pdf (1.44 Mo) Télécharger le fichier
hal-03594219 , version 1 (02-03-2022)
Benoît Audelan, Dimitri Hamzaoui, Sarah Montagne, Raphaële Renard-Penna, Hervé Delingette. Robust Bayesian fusion of continuous segmentation maps. Medical Image Analysis, 2022, 78, pp.102398. ⟨10.1016/j.media.2022.102398⟩. ⟨hal-03594219⟩
109 Consultations
178 Téléchargements
